Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer - Odor problem
I continue to have problems with the odor as well even after the bleach suggestion. This week I thought I would try to wipe dry just under the gray rubber gasket and my towel came out covered in a gray black mater that was slimy. My guess is that it is a lint off of the clothes. It is really gross and it lines the entire circumfrance. My husbanc put on rubber gloves and went in to try and get it out but that was really messy and didn't accomplish much. Help!
I am sure that is what is causing the odor we are all getting so how do we clean that part of the washer?
  • 6 more comments
  • tvaldez Feb 07, 2009
    Hi Joyce, it is the mildew smell. But I believe it is coming from the buildup of of wet lint (I am assuming it is lint).
  • vickster4 Feb 08, 2009
    I'm glad I'm not alone. I agree with tvaldez, sounds like a Whirlpool problem. I've also had my washer for 4 years and this stinky problem has just started. So has anyone found any home remedies for this? Is Whirlpool looking into this problem?
  • westport-Ct Feb 08, 2009
    I have had the same problem and have tried everything for over two years to no avail. I use only small amounts of special detergent and no fabric softener. I have tried several suggestions including afresh, bleach and another cleaner. I have even attempted to run several water only cycles in sanitary mode. All solutions have small marginal improvement that lasts about two days. I spend more time cleaing teh machine that cleaning my clothes!! Whirlpool cannot figure out how to fix.
  • Anngracie Feb 08, 2009
    I see the problem of mildew odour as one created by Whirlpool in the design of the machine. It just makes no sense that one would have to literally take the machine apart to find the cause. If bleach and other products are not working, we should be looking at a recall of these machines.
    Pat Vienneau
    Model number GHW9100LQ
  • Lissee63 May 15, 2009
    I have they same smell gross I did everything leaving all doors open wiping inside rubber using ahh fresh and the new tide product. doing the bleach cycle. This is the last whirlpool I get the last one was in a class action suit calypso I hope there will be a class action I will be in on that
  • kinikia May 16, 2009
    I have the same problem with the smell. Like everyone else, I have tried everthing I can think of and nothing helps. The only thing that seems to help the problem not get worse is leaving the door open a bit when not in use. I just bought something called Tide Washing Machine Cleaner which I am hoping will solve the problem. I believe this is a new product--I have never noticed it before. Anyone used it?
  • junabug May 26, 2009
    Our Duet is 3 yrs. old and the problem of bad odor just became noticeable. My wife wiped inside with lysol. I have checked gray rubber boot and it is clean. But odor persists. I have not disassembled hoses and have no solution. I will try calling Whirlpool, but am not hopeful.
  • JOYCE BROOKS May 11, 2010
    this is joyce
    What kind of smell is it exactly?
    does it smell like mold or rubber?
    blech should have killed the modl oder if that was what it was.
    let me know please
    joyce
I had this problem and I believe it is caused by slimy lint inside the hose that discharges the dirty water. I poured bleach in the hose and let it sit there for a while (the way the hose would normally curve prior to discharging into the slop sink). It has been good for about two weeks now.
Posted on Feb 10, 2009
It isn't fixed but I am not interested in paying for a solution. If there is a defect in the design of the machine, and it sounds like there is based on the number of other 'odor' problems, Whirlpool should be addressing it.
Posted on Feb 08, 2009
How do I remove odor from duet front load washer?
Assuming the odor is not a burning rubber smell or some other type of odor caused by a mechanical malfunction:
Remove the bottom of the washer (three screws I believe and above the drawer if you have one) and then open up the drain pump catch and clean it. You may want to put down some towels or even a bowl to catch water that will spill out. There are videos on how to clean this on youtube "Whirlpool Duet Water Pump Drain Catch". I believe this will solve the problem.
Oct 16, 2014 | Whirlpool Duet GHW9150P Front Load Washer
How do I get rid of a mildew odor in the Whirlpool Duet front loader?
bleach and bleach and bleach and bleach!!!!! also i notice more of a smell in washers when people only use liquid detergent and too much of it.
Tip: leave door open after every wash
clean with bleach and hot water regularly once a month
with no clothes on a normal cycle
alternate liquid detergent and powder (yes powder comes HE)
only use HE detergent
try these things and you will find your washer smelling like new again. but tthe trick is BLEACH and a lot of it. once you get a smell it takes a long time to get rid of it.
good luck and let me know if this helps
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smelling washing machine.....
Hi, did you wipe out the inside of the boot with the bleach? This is a big problem with all front load machines. If you call the Whirlpool, I believe they have a product out now to help the odor as well.
Vic
May 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer smells
I have a front load washing machine too and my instruction booklet says to run it on the clean cycle once a month with the bleach up to the max. I do this every month with out fail. I also the last load of laundry I leave the door ajar. It will usually dry completly in a few hours. Hope this helps
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Odor
What type of odor? If it is a bad smell, have you been running the bleach cycle to clean the washer as per manual directions? If not I would try this. Dan
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine odor
www.affresh.com this product has been devoeloped to lessen front loader odors. you NEED to be using an HE detergent. low sudsing ans specifically design for use with front loading washers.
Oct 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer
Increasing the water is not possible and would not help anyway. The odor is from bacteria. To kill the bacteria run a load without clothes on the HOT wash setting and add a cup of bleach to the soap dispenser. In the future to prevent it from returning use the hottest water allowed by the clothing care tag and use bleach whenever possible. If you don't like to use bleach or hot water you may need to repeat the cleaning once a month. Also make sure you are using a HE detergent. Non HE detergent can suds up and the suds may not rinse out with the water and can create an odor.
Jul 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a Duet washer with a severe odor problem. We keep the door open when it is not in use. We have tried the Affresh tablets with no success. I am currently running a bleach cycle weekly, and it only...
The Duet has a filter trap that's pretty easy to clean. There could be debris catching residue and not allowing the washer to drain right. Remove the toe panel with a torx bit and turn the filter handlt to the left. Have towels handy because there is always a gallon or two of water left in washers after they drain! Cleaning the filter trap should be regarded as regular preventive maintenance.
Leaving the door open will actually make the problem worse because it dries out the odor-causing residue and makes it much harder to remove. If your washer stinks with the door open or shut it's time for a good cleaning before it gets worse! The area of heaviest buildup is always between the inner stainless tub and the outer plastic tub. After your washer has been cleaned you'll need to change your washing habits so odor doesn't return. If this doesn't remove bad odor you'll need a good washer cleaner.
To compare washer cleaners watch this video
http://www.youtube.com/watch?v=Ua6OJPn0-fU
Apr 12, 2008 | Whirlpool Washing Machines
Odor that smells like gas going from the refrigerator
Mold and mildew can cause problems like this. It is even possible that a small animal may have invaded your home and gotten into the box somehow. Cleaning the inside of the box with a dilute bleach solution may help. For continuing odor absorption, place an open container, say a 1/4 cup, of baking soda (bicarbonate of soda) in the compartment. Change as often as once a week. The powder will absorb the odor.
Jan 15, 2008 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool Duet GHW9150P Front Load Washer Logo
1,435 people viewed this question
Dan Webster
Dan Webster
Sal De
