Question about Pioneer DEH-P6400 CD Player
Memory of presets
I cant get my radio stations and bass/trebble etc to save, so when i turn off the stereo i lose them and have to set it up all over again!! can anyone help?
    President:
  • 1,990 Answers
You need to Check the Wiring Harness from the Stereo. There is a Constant Power Memory Wire (Should be Yellow or Orange). This needs to be Connected to the Cigarette Lighter Power Wire for Constant Power Memory. Please Rate My Response! Thanks!
Posted on Feb 07, 2009
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
When i change stations on my radio it changes all the settings on bass and tremble on my 2007 grand prix?
Hi Nick,
Your radio might save the bass & treble settings with each station. Try choosing a station, set the bass, treble and any other variables (mid-range, etc.) and then SAVE the station to a button. Do this for all of the buttons / stations you like.
If this doesn't solve the problem, tell us about the radio (AM/FM/Cassette/CD and Factory or aftermarket - in which case we'll need to know the make and model of the radio.
Apr 24, 2015 | Cars & Trucks
When i preset my radio stations 1-6 while the power is still to the system memory of stations will stay but when the car stereo power is turn off for any amount of time and sterio is turn back on all...
Make sure the yellow wire is connected to a source that still has voltage when the key is turned off. The yellow wire controls the memory of the deck.
Jul 24, 2011 | Alpine CDA-9851 CD Player
Can't set the radio stations
When you find a frequency that you
want to store in memory, press one of pre-
set tuning buttons 1through 6 and hold until the
preset number stops flashing.
The number you have pressed will flash in the
preset number indicator and then remain lit.
The selected radio station frequency has been
stored in memory.
The next time you press the same preset tun-
ing button the radio station frequency is re-
called from memory.
May 29, 2010 | Pioneer DEH-2800MP CD Player
I can't preset radio stations
this is how i preset my stations, im not sure if you have done this before.
fm can save 20 stations and am can save 12
1] chose your desired station
2] press & hold the play/memory button until P01 pops up and flashes
3] to save the station, press & hold the play/memory button
if you'd like to save another station, then repeat steps 1 & 2,
then press the play/memory button again until P02 pops up,
repeat step 3.
to listen to your preset station, all you have to do is press the play/memory button.
hope this helps
Mar 12, 2009 | Starlite Next Play Clock Radio with iPod...
Can't Set Presets for Fm radio
when u get it to the radio station u like.... on ur cd player u should have buttons 1-6 or somethin close.... when ur at the station u want to be preset... pick a number 1-6 and hold that number in for about 5 seconds... it should notify u some how... it should preset itself when u do this
Jan 16, 2009 | Sony CDX-M8800 CD Player
Radio Station Presets wont hold
hi girlygirl 1
the problem is your ignition and your permanant battery live wires are the wrong way round all you have to do is remove the stereo and you will usually see a red wire plug into another red wire and a yellow wire into another yellow wire all you have to do is change the red to the yellow and the yellow to the red and it will hold the memories fine hope that helps !
Nov 19, 2008 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Jvc car cd/radio
The radio was improperly installed; there are two 12V leads, one services the radio when on, the other, only the circuitry for the clock and presets.
Eventually, this shouldn't be needed if the manufacturers ever think about using a little bit of flash memory for the presets and a coin cell for the clock.
You didn't give any model number so researching the manual is impossible.
If you can find the model number, look for a user's (or installation) guide on line to find the wiring info.
Aug 25, 2008 | JVC AM FM CD DET FACE CAR STEREO
EXAD KD - AR5000 Programming
Do you also lose your clock and radio station presets?
Nov 08, 2007 | JVC Arsenal KD-AR5000 CD Player
Stored settings and auto eject
Hi. SOunds like another case of power problems. Your deck has 2 power wires. One is yellow th eother is red. One is constant 12 volt battery power, the other is a switched 12 volt power, only has power with the ignition key on or on accesory. Get yourself a test light. I almost bet you do not have the constant 12 volt power to the deck, therefore your deck cannot hold its presets...
Sep 25, 2007 | Dual XDM6830 CD Player
Pioneer DEH-P6400 CD Player Logo
422 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
