Question about Kodak Cameras
My kodak z1275 wont power up
My kodak z 1275 wont come on, i have tried different batteries and no power
    President:
  • 2,761 Answers
If the camera has recently been dropped it may have lens damage that is preventing it from powering up. If it hasn't been dropped, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Posted on Dec 06, 2009
Can I use the same USB cable to charge the batteries as well as transferring photos to computer from Kodak EASYSHARE Z1275 12.0 MP Digital Camera providing that I am using rechargeable batteries inside the...
No. The Z1275 is not a battery charger. If you want to use rechargeable batteries then you must charge them outside the camera using a separate battery charger.
Aug 19, 2013 | Kodak EasyShare Z1275 Digital Camera
I have a kodak easysharez612 camera.I try to charge the battery with a different charger and now it wont turn on and the camera gets hot.what could be the problem
If the camera or most likely the batteries are gets hot then the camera is faulty and it is drawing too much power from the batteries.
Apr 11, 2012 | Kodak Cameras
Wont power up ,kodak easyshare c360
Please make sure that you're using fully charged battery
Remove the battery, press and hold the power button for 5 seconds and then reinsert the battery..
Try using a different battery to check whether the issue is with the battery..
You may also check the battery poles using a multimeter to confirm this if you do not have access to a different battery..
If the issue persists, service may be required.
Thanks for understanding.
Jan 05, 2011 | Kodak EasyShare C360 Digital Camera
My camera wont charge
have you check the charger? or is there a power on the outlet? try to charge it from different power source
May 25, 2010 | Kodak EasyShare V1003 Digital Camera
Camera shuts off when plugged into computer wont turn on while plugged in trying to put pics on computer
The camera needs battery when connected. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
NOTE The cameras LCD screen will remain black throughout the transferre.
If you're experiencing that the computer is not reacting to the camera at all try the following:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 27, 2010 | Kodak Easyshare C813 Digital Camera
My lense will not open anymore?
I assume that there is no power on the camera when the lens gets stuck. Please try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 14, 2010 | Kodak Easyshare M341 12.2MP Digital Camera...
Why won't camera switch on and red light flashing all the time i have bought a new battery but still won;t switch on and light still flashing many thanks
hi, what type of batterys have you brought as most normal batterys you buy wont even switch the camera on you need hi power batterys such as lithium or even better go into a camera shop and they will have special high power bats, normal bats wont even switch mine on so give different batts a try
let me know how you get on or if you need fyrther assistance ok
Nov 10, 2009 | Kodak EasyShare Z730 Digital Camera
Cameras Logo
100 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
