Question about Vizio L37 Television
Hdmi 2 on my vizio 42"
I have a SV420XVT Vizio and i hooked up a Sony RDR-VX560 VCR-DVD Combo. Did just like instructions told me hooked it up the Hdmi cable and the white and red audio. The picture is great but i have a Black bar on top and bottom. i can not ajust it try everything, When i play a new dvd it plays in for screen but if i try to tape a tv show i have to use the wide format which makes the picture bad. I don't know if its the DVD player, or something else. i hope i can find someone out here that a vizio and a dvd player hooked up no problem. Vizio tech support told me there wasn't nothing i could do. I hate to go and get another DVD player and have the same problem.
SOURCE: vizio sv420xvt pip
You have to go into the "Parental" settings and change the "Rating Enable" setting to off. Default password is 0000. The PIP will not work if your second source is fed into one of the AV inputs. It must be a composite or digital input. You should see the PIP menus once you change the Parental setting even if there is no other source turned on. This info is not in the book - had to call tech support.
Posted on Jan 17, 2009
SOURCE: How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Posted on Mar 01, 2009
  • 10 Answers
SOURCE: I want to hook up my bose speaker systerm to my new vizio tv
Real easy, get a RCA audio cable (red and white ends) that is long enough to go from the tv inputs to your receiver inputs. Plug one end into the audio out on the back of your tv, then plug other end into input on your receiver (tv, cd or vcr). Now everything going to tv will output to receiver also. You may have to go into the TV menu and under audio, set audio output to fixed. Then you can change the volume on your receiver which is best way to go.
**Advanced** If your TV and receiver has optical capability you can use an optical cable instead.
Good luck,
Posted on Apr 04, 2009
tvtek
  • 1284 Answers
SOURCE: I have a Vizio SV420XVT. There is a green line
A single line out means a bad LCD panel..The cost for parts will exceed the cost of replacing the TV...
Posted on Jul 23, 2009
  • 10 Answers
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
Posted on Oct 10, 2009
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
I have a Sony RDR-VX560 DVD Recorder / VCR Combo, accidentally put it to dvd1 instead of dvd3...ive tried holding the enter button and all that and nothin works..any way to get factory reset or any help?
Hold down Enter button on remote and while holding Enter press and hold 1 (numeric) on remote for 3 or 4 seconds, now remote is set on dvd1 mode and dvd recorder will accept its commands.
Thanks.
Mar 19, 2010 | Sony RDR-VX560 DVD Recorder/VCR
Sony rdr-vx560 systems menu won't come on screen
It depends on which DVD you are stuck. Use the following numbers to resolve the problem. DVD1 = 1, DVD2 = 2, Aand DVD3 = 3.
Please hold the ENTER button. While holding down the enter button press the corresponding number button (ie, 1 or 2 or 3)
Hold down the ENTER button and the relevant number button (1,2,or3) for more than 5 seconds.
Jul 12, 2009 | Sony RDR-VX560 DVD Recorder/VCR
Need remote control code for Sony RDR-VX500
Try these codes. 20533, 20864, 21033, 21904,
21903
May 26, 2009 | Vizio L32 32 in. LCD HDTV
Can't get my sony dvd/vcr model rdr-vx560 to record from my tv
I just gave up. I was told this tv didn't have a video input. Just decided to recford on my old vcr and just use the dvd/vcr to dub tapes to dvds. thanks anyway. JoElla
Jan 11, 2009 | Televison & Video
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Vizio L37 Television Logo
75 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
