Question about Sharp Office Equipment & Supplies
Connecting Sharp AR M-350N to Wireless Network
I have a Sharp AR M-350N and can't get it to connect to my router. Any suggestions?
  • 29 Answers
Ping the IP address if the request times out check your cables , try anothere port in router repalce router
Posted on Mar 09, 2009
Can i connect new pc to old connection
You simply need to disconnect old computer from the network and connect the new one.
Are you trying to connect wired computer or wireless?
If you are trying to connect a wired computer then you don't need to do anything.
Just take out the Ethernet cable from the old computer and connect it to the new computer.
If you are connecting a wireless computer to the network then make sure that you have all the settings of your wireless router.
If your wireless network is secured then you should know the correct network key.
What is the operating system on your computer?
I will suggest you a website " The Router Setup " which may help you connect your new computer to the old wireless network.
May 17, 2012 | D-Link AirPlus DI-524 Wireless Router
I can not get my wireless router to find my or take my ip address
Your wireless router once you connect to it will give out an IP. You can only setup in the router software what your machines MAC address and preset it to be given an IP of your choice.
So in short your wireless computer should find the wireless router via.. SSID and its password then once authenticated your machine will be given and IP and gateway to access your network.
If you are having trouble connecting to the wireless router. Then I suggest connecting to it via the wire first make the needed adjustments and then retry the wireless connectivity.
this link will bring you to the manual for your router http://www.dlink.com/products/?pid=DIR-615&tab=3
GL
hope this helps
Don
Aug 08, 2011 | D-Link DIR-615 Wireless Router
Get no signal from router
There are many network-related settings that need to be configured on the system for connecting to a wireless network. If even one of these settings have not been configured properly, issues will come up. All users facing problems with the use of wireless networks are advised to check network-related settings such as access points, IP address in use and reconfigure them if they are not properly set. Users are also suggested to check the firewall settings to make sure that the firewall is not blocking network connections.
http://router.iyogi.com/wireless-network/wireless-network-not-working.html
http://www.informationweek.com/news/mobility/802.11x/216403550
Jun 10, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My router is connecting to the network and broardcasting the internal netowrk but not broardcasting any internet. The internet connection work fine if i plug the wire straight into my computer.
To connect to the router using a wireless connection, the computer's wireless card needs to be configured with the router's wireless settings, ie. SSID and encryption key.
The encryption key is configured in the router's wireless settings.
I suggest you use WPA or WPA2 encryption because it is the latest and provides stronger protection.
To change or see the encryption key and/or secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 30, 2011 | Linksys Wireless-G WRT54G Router
Connecting sharp AR 5316 to a wireless network for office use
With great difficulty.... Seriously though, you MUST get the driver for each operating system, Install each Driver on each machine, and then simply connect each computer to the printer as a "Networked" printer. I may be efficacious, to have all drivers on every PC, all in same Directory so that each is available to each other...Right ALL machines, must be in same WORKGROUP, ALL have a password, The printer MUST have a name, Install the drivers as Administrator.
May 12, 2010 | D-Link Air Plus DP-G310 (dpg-310) Print...
I have a Dell Inspiron 6000 w/ window xp. I show my wireless connection on the signal is excellent but when i click internet explorer its says its connect to internet - i dont have working offline clicked...
Try connecting to another wireless connection... if it connects to another connection and you get to the internet, then it is something with your wireless router or modem. Your PC can "see" a wireless connection, so it is NOT PC hardware.
It sounds like you can connect to the router, but cannot go through the router to get to the internet. Probably a simple issue with your modem or router. Try power cycling the modem, and power cycling the router. Then restart your PC and try connecting again.
If all that fails, try installing Mozilla Firefox and see if that will get out to the internet. It may be a problem with Internet Explorer.
Sep 09, 2009 | Dell Inspiron 6000 Notebook
Westell 327 router not connecting to my new Dell Laptop
So you having problem issue on the wireless router?
Try this:
1. See the icons on the down-right.
2. There'll icon with wireless connection.
3. Try to refresh it, and you'll detect you Westell router.
4. Click it twice, and you'll get connected to your wireless router.
Hope this help! Pm me if there's any questions =]
Jul 07, 2009 | Westell Wirespeed VersaLink...
Connecting with internet
Yes, that is possible since you have a wireless router. Router can share internet connection. Go to this link this will help you setup the wireless connection (secure it if you want)
http://www.portforward.com/english/routers/wireless/Dlink/DI-524/wireless.htm then on the very bottom there is an option how to Configure Windows XP to connect to your wireless network.
I suggest this because it would be better if there is encryption on the network so people wont be able to access your internet for free (unless you give them the security key)
Sep 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless problems with windows vista
You just need to remove the preferred networks on your vista, follow this.
Right click the wireless icon>network and sharing center>manage wireless network>remove all preferred networks.click OK.
Then connect again to your network that should solve it.
Jun 13, 2008 | Linksys Wireless-G Broadband Router
318 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
