Question about NetGear WGR614 Wireless Router
Need to change netgear router rp614 from dsl to cable
Recently swithced from bell internet to rogers internet and the router is set up for dsl i need the instructions to change is to cable so we can use both computers in our house. thanks for the help
  • 33 Answers
Hello
First connect one of the ethernet ports (LAN) to your computer.
In windows to this:
XP: Start -> Run -> write CMD and press ok-> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex 192.168.0.10 or 10.0.0.1).
Vista: click windowsmenu icon-> write CMD in search field and press enter -> Black window pops up-> write IPCONFIG and press Enter. -> Look for Local ethernet connection and write down the ip adress outside default gateway (f.ex 192.168.0.10 or 10.0.0.1).
Open a webbrowser and clear det adress field, enter the adress (with the dots and no www.) you wrote down from default gateway and press enter.
If you get promted for a username and password the default is: username: admin password: password (you can find it on the side of the netgaer box under deafult accsess.
If you cant get in try to do a "hard reset" (push the reset button for 30 sec with a pen).
You are now in the web user interface for you netgear.
On your lefthand side, you should have a blue menu, click on the first option on the top and run the setup wizard, dont change anything (dont choose that your connection needs a password to connect) just use the default settings. Remember to press save on the botom.
You should now be ready to use your netgear router.
If this guide didnt fix your problem, i need more details to help you.
Check with your new service provider if they require a username and password to connect (PPPoE).
Posted on Feb 08, 2009
Netgear rp614v4 as a switch
This router acts like a switch automatically, you can converse between ports on the same LAN connections without any setup.
They all need to have the same network setup, the same gateway address and DHCP setup.
If you are not accessing the internet that's all you need.
See manual http://downloads.netgear.com/pub/netgear/files/RP614v4_RM_12Jun08.pdf
Apr 02, 2014 | NetGear RP614 4 Port Cable/DSL Router with...
How to setup a wireless network for xbox live using embarq 660 series modem and netgear wnr2000 wireless router
Here is a link to setting router up to use with xbox it is a different router however it should be the same concept hope it helps just read the forum http://forum.teamxbox.com/showthread.php?s=&threadid=135051
Oct 02, 2010 | NetGear -DSL Web Safe Router/ RP614 -...
We setup our router and it works for the computer and 1 laptop but i cant get my laptop to connect to the internet.
if you are able to connect to internet with your desktop and not connecting through laptop, i suspect there is a problem with your laptop's Port settings.. run these commands in command prompt. (run -> cmd)
1. netsh winsock reset
2. ipconfig /flushdns
after this, windows firewall should be turned off. Then try to reconnect your WLAN. Give suitable WEP Key if you got.. Then Browse.. Be sure that your Laptop lies in connectable distance from Router. Good Luck
Jun 09, 2010 | NetGear -DSL Web Safe Router/ RP614 -...
TalkTalk Modem Smartax MT882 to Netgear RP614 problem
Well your modem and router IP is same thats why you can't connect your router with modem
your have changed IP of the router,please follow steps to resolved your issue
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.0.1 address bar. press enter
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Hope it can resolved your issue
Happy to help
Thanks for using Fixya
Apr 04, 2010 | NetGear RP614 54 Mbps 4-Port Web Safe...
Twice after using Google's gmail video chat with our RP614, our internet access stopped. I had to recycle the power on the RP614 each time. Is this a known issue?
I can't think of a connection between the two events, esp if it happened only twice. I own a similar Netgear router (wi-fi tho and not DSL), and find it very reliable.
Nov 07, 2009 | NetGear -DSL Web Safe Router/ RP614 -...
NEtgear RP614 cannot connect after a electricity shortage in our home :(
Reset the router to factory default. Usually done by unplugging the router hold in the reset button and plug in the router wait 30 sec. release reset button Wait 30 more sec. and unplug router again. Then reset your computer to obtain ip address automatically in network properties. Next shut down your computer, router and modem. First re-power the modem, give it time to boot (about 2 to 3 Min. for Cable and dsl or 7 to 10 min for satellite), next re-power the router, again give it time to acquire it's info (about 2 min.) then start your computer and try to access the Internet, all should be well...
Good luck, and have a great day...
Tim
Mar 23, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
The light of internet is orange,not yellow.
The router should have reset button on the back. This will reset it to factory defaults. If you have an ISP that gives you internet without a username and password like rogers then you should be good to go. If your ISP is like Bell then you will need to get into the website of the router and configure it.
Nov 28, 2008 | NetGear -DSL Web Safe Router/ RP614 -...
Changeing Adsl to Dsl router
You need to configure first that RP614 to work with your network.
May 09, 2008 | NetGear RP614 Router
Macintoshes and the RP614 Router Gateway
You need a Macintosh computer running MacOS 8.6, 9.x, or 10.x. (Netgear products are not supported for versions of MacOS before 8.6.) You can use the RP614 with an eMac, iBook, iMac, PowerBook, PowerMac, or PowerPC as long as they are running one of these versions of MacOS. You also need a few Ethernet cables to make the connections between the router to your modem for internet connection and from the router to your computers or peripherals. Topic 2. How do I prevent my Network configuration from being lost when I restart my computer? When making configuration changes for MacOS it is best to use Configurations (MacOS 8.x or 9. x) or Network Location (MacOS 10. x) settings instead of just changing settings for each category (TCP/IP, AppleTalk, AirPort, etc.). If you just make changes to your settings, they may be lost when you restart your computer unless you have saved them in a Configuration or Network Location. To create a Configuration in MacOS 8.x or 9.x: 1. Open AppleTalk (or TCP/IP) from the Apple Menu in the upper left-hand corner of the screen. 2. From the pull-down File menu select the Configurations option. 3. Choose New Configuration. 4. Type in a name for your new configuration (Netgear Router). 5. Make your changes to the AppleTalk (or TCP/IP) settings. 6. When you close AppleTalk (or TCP/IP) choose Save Changes. Whenever you make Configuration changes for settings in MacOS 8.x or 9.x, open Configurations from the File menu or by pressing Command-K. Saving your changes in Configurations means that they will not be lost when you reboot your computer. To create a Network Location in MacOS 10.x: 1. Open the Apple Menu by clicking on the Apple icon in the upper left-hand corner of the screen. 2. Select System Preferences. The System Preferences window displays. 3. From the System Preferences window click Network under Internet & Network. The Network settings window displays. 4. Click the Lock icon (if necessary) in the lower left-hand corner of the window to unlock the Network window so you can make changes. (You may be asked to type in your User Name and Password.) 5. Click the pull-down menu next to Location at the top of the Network window. 6. Select the New Location option. 7. Type in a name for your new Location and click OK. 8. Make your changes to the TCP/IP, AppleTalk, and AirPort settings. 9. Click the Lock icon in the lower left-hand corner to prevent further changes. The Apply configuration changes? Window displays. 10. Click Apply to apply the configuration changes for the newly-created Location. 11. Close the Network window. Topic 3. How do I connect a Macintosh to the RP614 Router Gateway? MacOS 8.6, 9.x, and 10.x 1. Set up your system for installation. 2. First make sure your ISP connection is working. Try testing your computer with the ISP directly to make sure you can successfully make a connection to the internet. 3. Connect your DSL or cable modem to the Netgear Router. 4. Log on as Administrator (if required for your system to make configuration changes). 5. Quit all other applications. It's best when configuring MacOS 8.6 and 9.x to use the Configurations settings for AppleTalk and TCP/IP because they should then retain their settings when you reboot. (Use Network Locations to save your settings changes in Mac OS 10.x.) If you just change the settings but don't use a Configuration or Network Location to save your settings changes, you may lose those changes when you restart your computer.
Feb 19, 2006 | NetGear RP614 Router
NetGear WGR614 Wireless Router Logo
96 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
