Question about Poulan Garden
Poulan Hello, I have a Poulan 2550 chain saw that I hadn't used for a couple of years. I discovered the fuel lines had completed dry rotted. I have new lines but don't know where they go from one end to the other. Is there a blown up view of the saw available online anywhere? Or can you help me? Many thanks, Howard
  • maliplayer Feb 08, 2009
    Thanks so much. That was all the information I needed to be up and running again.
dontbother10
  • 2220 Answers
SOURCE: installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Posted on Sep 14, 2009
dontbother10
  • 2220 Answers
SOURCE: fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Posted on Oct 24, 2009
  • 4088 Answers
SOURCE: Fuel lines rotted off of my McCulloch 4600 chain saw
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. Hope this helps!
Posted on Jul 18, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I need a schematic drawing
Go to this page:
http://www.jackssmallengines.com/help.cfm
Choose
1. Poulin
2. Poulin Pro
3. Pole Pruner
4. Gas
Then select either PP446E Type 1 or Type 2
If you need parts for the attachments then choose attachments and find yours.
This will get you straight to the engine:
http://www.jackssmallengines.com/help.cfm#AssemblyPartsSearch'model_3hfQcmydHGxAIk/GvlHpyA=='assembly_/GhQJfqNUvNbNmAjA03NAg=='brand_ahjxOQtsOoMBNqd6InjYkA==
Thanks for choosing FixYa.
Kelly
952-051549
Posted on Oct 02, 2010
bbap
  • 71 Answers
SOURCE: i have a 2001 poulan
I can describe it but see if you can follow this link which I uploaded a couple of weeks ago. If you cannot, just re-post and I'll describe it instead.
http://www.flickr.com/photos/29932328@N04/5021387817/
Posted on Oct 03, 2010
Poulan 2550 18
There is no problem as long as the bar is the right bar and the new chain you use is the right pitch for the sprocket that is on your saw.
Nov 14, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan PP4218 avx; tube (line) inside gas tank connecting filter has rotted and need to replace. Is there a tool used to push line onto "nipple" inside tank.
cheapest way is a new fuel tank from e-bay that has it all installed
you can remove the rubber grommet around the lines to get it out then get a new filter to push on the line BUT will it be cost effective against what can be obtained from e-bay
Aug 01, 2013 | Poulan Pro Chain Saw 46cc 20"
Poulan chain saw model #2025 - fuel lines dry rotted and disintegrated. There are 3 fuel lines: l from gas tank and 2 from primer button but only 2 fuel ports on the carb. What goes where and how?
You should have 2 to the tank, the one with filter coming from tank goes to nipple on right side of carb, the nipple on left side by primer bulb goes to primer bulb and other from primer bulb back to tank as return line, how it should work is when you push primer bulb it pulls fuel from tank through carb and back to tank on return line so watch in tank orleave one line out that you think is return line and see if gas comes out when you prime, but remember it goes through the carb first before it goes back to tank, had a pic but too big to put on site sorry, 2StrokeJim
Oct 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need a digham for poulan chain saw fuel lines the old ones dry rotted and i dont know how to install the new ones
James I have the same problem. Can you help with a picture or instructions on how to fix please
www.oneway@bellsouth.net
Thanks, .
Oct 03, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
May 07, 2010 | Poulan ES350 16" Chain Saw
Chain saw won't start
Check the fuel filter for plugging (which is common when fuel is left in the machine over winter storage). You should run the carburetor dry after emptying the fuel tank for storage.Hope this helps!
Apr 14, 2010 | Poulan Pro Chain Saw 46cc 20"
Fuel lines have rotted off. need to replace then
Mr Tittle;
Poulan.com
HTH
Lou
Oct 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Installing fuel lines for, poulan 2150 16''
Poulan.com
Lou
Sep 14, 2009 | Poulan Garden
Poulan #2550 farmhand saw, Put a new carburetor on saw still not getting gas to carb?
Try emptying the fuel tank, and with small flashlight inspect the fuel line and the sump pick-up screen inside the tank. You may be able to gently retrieve it with a stiff wire hook. See if the hose is cracked/broken of if the screen is clogged. If all is well, be sure there are no kinks in the entire fuel line.
Hope this helps
Feb 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
137 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
