I have a Performa washing machine that was working fine at our previous location. I moved to a new house and installed the washer and it works but it won't go through the rinse cycle. It just stops and sort of hums. Do you have any idea what it could be?
I also helped a friend move their front loader last week and it worked at the house but when we hooked it up at home we were having the same problem as I'm having with mine.
-   I also have a Performa washing machine that won't go through the rinse cycle. It just stops and hums. I have listened to the hum and seems to be comming from the water solonoid. If you undo the top back cover behind the timer there is a paper cicuit diagram for a reference. I am going to try and track down the cause in the next few days
Hi
After investigating the logic of the machine and how the timer works, I traced it down to the cold water solinoid rubber stopper It had crud in it and just hummed. After cleaning it out it ran just fine..
This is an easy fix.. If it cant run water it wont go to the next part of the cycle.
I hope this helps. I have more info if required.
Ashley
Performa begins cycle immediately without filling with water. I tried advancing through cycle, still...
(More)
Performa begins cycle immediately without filling with water. I tried advancing through cycle, still no water. I let the washer do final spin hoping it would reset....no water. I've tried just cold, just hot, and unplugging to reset. All tubes are connected and water is on. I had just completed a prior load with no problems. New load....no water.
it quit last night with a full load of clothes and water in it. has a burning electrical smell. is...
(More)
it quit last night with a full load of clothes and water in it. has a burning electrical smell. is this washer toast?
