SOURCE: unlock code for LG one box one cinema
is 4 your home code region i know 0 is all in main settings sumware they shoudl show rgion free ok if ot dvd sdont surport it ok usally have to a buy a region free player to play all disk from all ove rthe world ok thx agian nick helpap
SOURCE: pioneer XV-DV424 dvd player does not
Is the player a region 2? Just because you are in region 2 does not automatically make a player from another region change....accordianaman
SOURCE: Making my DVD Player Region Free
It is not a permanent hack, you will have to to it over for every out of region movie you put in.
1. When "REGION CODE ERROR" shows on screen after you've input your wrong-region DVD you push "ON SCREEN".
2. When the DVD-menu is showing push "ON SCREEN" again and another DVD-menu will appear.
3. Move the arrow over to the clock and press enter. The menu asks for "TIME" and you write 0:00:00 and push enter.
4. You will now see the menu for the movie. Remove the DVD-menu by pushing "ON SCREEN" once. You can now watch the movie.
SOURCE: Unlock codes for Pioneer DVD player
Pioneer DV-667A
Converting the player to Multi-Region:
Requires the use of a Palm Pilot w/Palm OS 3.0 or later and the OmniRemote Pro from http://www.pacificneotek.com/
(Other PDAs using Palm OS and compatible with the OmniRemote Pro from http://www.pacificneotek.com/ can also be used).
1. Program the Palm Pilot/OmniRemote. For instructions on programming the Palm Pilot/OmniRemote click How to Program the Palm Pilot.
2. Power on the DVD player without any DVD in the tray.
3. Keep the programmed Palm Pilot close to the IR port of the DVD player.
4. Start the OmniRemote program.
5. Place OmniRemote in TV mode and tap the "0" button on the OmniRemote.
6. The DVD player will power off.
7. Power the DVD player on again. Check the Region-free status by playing a DVD.
SOURCE: How to multi region my Pioneer XV-DV55
Most have "hack codes" but yours is in a select group of a few that simply cant be done with a couple pushes of a button.
As far as I am aware the only way to get thesemachines to play Region 1 discs is to have them chipped. A variety of solutionsare available, and it needn't be expensive (typically £30 to £70) but youshould be aware that any internal modifications to your players wouldinvalidate the warranty. Have a look at the following web sites for moreinformation:http://www.techtronics.com/uk/shop/50-000-dvd.html
http://www.maxking.co.uk/dvdmod.htm
http://www.dvdchips.co.uk/
I know you were looking for a free solution you could do in a matter of seconds and sorry it didnt work out that way. Regardless, I hope I pointed you in the right direction and feel free to ask if you have any more question.
Happy Holidays,
TJ
My pioneer xv-dv8 cd/dvd player is locked to region 4 (Brazil) and would like to make it region 2 or unlock it completely. Many thanks.
If you have solved this problem, could you help me?
Many thanks from Brasilia, Brazil.
Z
