Question about Amana Microwave Ovens
No power Shorted removing bulb
  • William Miller
    William Miller May 11, 2010
    Please reply back with your model number so we can help you.
    Novelist:
  • 140 Answers
It is obvious that you also blew out your fuse. It is easy enough to get to though if you will just take the cover off (just a few screws) and be sure the unit is unplugged. The fuse will be at the far backright as you look from the front. It is a ceramic fuse and not one that you can see through. Take it off and get the right replacement fuse. Home Depot or Lowes or electronic supply house and help you with that. Put the new one in and put everything back together and you should be back in business.
Posted on Feb 09, 2009
How to turn the oven light off on my Kenmore Elite Electric stove model790.
You should have either a shorted out door switch or a shorted out light switch on the control panel.
Removing either one and unplugging it should show you which one is the problem.
God bless your efforts.
Nov 30, 2016 | Kenmore Microwave Ovens
Counter lights
Hello!
Please consider troubleshooting the circuit of the oven, some connection in it is shorted causing the breaker tripped off.
Hope this help.
Melnavz
Mar 14, 2008 | Samsung SMH7174BC Microwave Oven
I shorted out the counter lights on my frigidair microwave. The microwave works but not the lights. I've replaced the bulbs. What next?
The metal base may have fused together from electrical arcing when the old bulb was removed. The entire bulb receptacle (socket) will have to replaced. If you cannot do that yourself, the cost would be excessive. Just live without the light as long as the microwave gets the job done.
Dec 10, 2014 | Frigidaire FMV157GB Over-the-Range 1.5 Cu....
Non-working furfact light
It is common for the light circuit trace to blow out if the light bulbs shorted out when removed while energized. If the trace is good then there could be a bad light relay
Nov 12, 2014 | Microwave Ovens
Why do the light bulbs stay lit after I have replaced the bulbs?
If the bulbs were replaced with power on the oven, the the device supplying the power to the bulbs (possibly a triac) may have been shorted out.
Jul 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Lg lmh2016st microwave shorted out after changing lightbulb now doesn't work
We see and repair this a lot. The problem is on the controller assembly.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Dec 01, 2013 | LG LMH2016ST
No power to oven after removing light bulb
What happend is that when the bulb broke the filiments touched (shorted out) and caused the reset switch on the unit to set>>>you need to find the reset button on this unit, look at your service manual. Additionally on some units there is a fused link internally, that may have blown>>>>both are an easy fix, so dont throw it out.
Good luck,
Geodesy
Sep 22, 2009 | LG Over-the-Range Microwave
GE Spacemaker XL1400 Microwave - Lights wont cut off
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too, due to a shorted relay.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Aug 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Majic Chef cabinet mounted microwave oven model VM11B-8P
On the electronic control board, the circuit trace will open like a fuse if the light bulb power becomes shorted. If you or someone knows how to use a soldering iron, this can be repaired.
1. Remove the top grille. (Two screws on top)
2. Remove screw above button panel. Push up on panel to remove.
3. Remove circuit board from panel. Look on reverse side for a burned, open circuit trace.
4. Repair circuit trace everything should work again....
Jun 15, 2008 | KitchenAid KCMS145J Microwave Oven
Light in convection shorted out when replaceing blub
This is most often caused by the filaments shorting when the bulb blows, or by not disconnecting the microwave from the power line when removing or installing a bulb.
This is a problem with the control panel assembly, which we repair nationwide for $39.95.
We have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams by entering your model number here: http://tinyurl.com/gv383
Oct 09, 2007 | GE JEB1095 Convection/Microwave Oven
Microwave Ovens Logo
265 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
