Question about Inverter Welding Tools
Looking for parts for saf presto 135 inverter welder
Cant find english web site
    Habit-Forming:
  • 27 Answers
Hi
my name is Rob, I may be able to help
What parts do need?
this link is for the current models
http://www.saf-fro.com/en/saf-fro/plasma-cutting-1.html
Saf have a base here in the UK
SAF WELDING
2 Low March Industrial Estate Low March, Daventry, Northamptonshire NN11 4SD
p: 01327705511
if the parts you need are generic, I can help.
If you need circuit boards repairing or torch parts I can help
Regards
Rob
Posted on Feb 08, 2009
How do I get a manaul for CT416 arc/tig welder
Did you look on the manufacturer's web site?
Dec 04, 2014 | Welding Tools
I need Q1 transistor for 135 hobart welder
The transistor is mounted on the main circuit board, you cannot buy the part from Hobart or Miller, they only sell the complete circuit board.
If you can read any part numbers from the transistor you can purchase the part from a electronic parts supplier.
Jul 13, 2014 | Hobart Handler 140 Mig Welder
Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Mar 19, 2010 | Welding Tools
Lost butter melter/measuring cup for #04820 Presto PopLite
You can call their customer service number 800-877-0441, or
go to their web site www.gopresto.com and look for service parts.
Jan 06, 2010 | Presto 04820 PopLite Popcorn Maker
Hobart handler 135 feed motor for wire doesn't feed wire. motor is ok I tested it with seperate power source. No power to motor from main board or ??????
check the SCR ,looks like a big transistor mounted
to a heat sink or some of the older units had a relay
in-line with a fuse , I have a older Hobart and it is
a great little welder. If you snap a pic of the P.C.
board and email it ill rsheehan@northernsteeldesigns.com
point out what parts to check.and replace.
Rob
Dec 06, 2009 | Hobart Handler 140 Mig Welder
My Handler 135 mig welder , welds and then cut out will not feed no more .Where could I find a parts for internal parts for Hobart 135? I would love to find a direct location to order this internal parts.
hi if the set cuts out after 10 /15 min on full power the thermal cut out switch is doing its job if it cuts out after 2 or 3 min it is faulty it is a bi metalic switch and is clipped on the main transformer take the wires off it and join up try the set DO NOTweld without it as you will overheat the transformer these little sets only have something like a 20% duty cycle hope this helps merlin v12
Aug 14, 2009 | Hobart Welding Tools
Northern tool mig welder,120 volt with gas.The wire feed is not working.When i pull the trigger the wheel that feeds the wire to the gun does not spin,even with no tension on it.The fan works and the...
you are going to need to remove the wires going to the wire feed motor, then take a volt meter and check the wires when you pull the trigger. this will tell you if the motor is bad or another problem
Apr 14, 2009 | Welding Tools
Looking for owners manual for presto gran pappy fryer
Manuals can be downloaded on the Presto web site www.gopresto.com. Down load the model 05411, it is the same unit.
Apr 04, 2009 | Presto 05410 Granpappy Deep Fryer
Presto griddle model 07034 power cord
Here is a web site that you can get the cord from.
http://www.pressurecooker-outlet.com/7034.htm
Good Luck And Please rate FixYa!
Dec 11, 2008 | Presto 07034 Electric Skillet
Welding Tools Logo
736 people viewed this question
Top Inverter Welding Tools Experts
Robert Lee
Level 1 Expert
Tom Chichester
Bud H
Are you an Inverter Welding Tool Expert? Answer questions, earn points and help others
