hi, i have just bought a hp G60-214EM notebook, and I am unable to connect it to the netgear on my pc. when i tried to connect, it says that the netgear was not the right model. I have a Dg834pn, not a wgr614 or wpn824. is there anyway I can change the settings to make both my pc and the laptop work. I am not very confident on the computer, this is a very new to me. If there is a way for me to solve this, and could you please explain in simple terms. thank you
Comments:
Feb 08, 2009
- Attempting to connect HP G60-214EM notebook to Dg834pn wireless rounter. when I tried to connect, this router was not in the list of available wireless. it says that hp network assistant currently does not support router I selected. Any ideas
Feb 09, 2009
- thank you, that got it sorted. it was not enabled, the username and password worked, i had no idea of what to put in when they asked for it. thanks again for getting it sorted. have a fab day, helen
-   I have a neatgear 834G and I am trying to configure my WEP. I am attempting to type in the address(http:168.192.0.1/) but it's not connecting to the web when I enter that address -   Guest
Helen, you should be able to connect from your laptop to your router wirelessly. From what I understood your router is hooked up to your PC directly. If that's the case from your PC connect to your router and enable wireless. Go to Netgear support web page to find out how to do it. Once enabled, you should see your router's name in the list of available wireless networks on your laptop
Comments:
Feb 09, 2009
- Helen, if you open http://192.168.0.1/ from your desktop computer you should be able to login to the router configuration pages. Default username is "admin" and password is "password". You should be able to configure wireless access from there. It is probably not enabled. I found a link to manual for your router as well in case you lost it: http://kbserver.netgear.com/pdf/dg834pn_ref_manual_11Nov05.pdf#xml=http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=6672999&action_code=6&highlight_info=352321589,12,23&turl=http%3A%2F%2Fkbserver.netgear.com%2Fpdf%2Fdg83
I suggest you first try enabling wireless connection without any encryption and see if your laptop connects or can see the router. Then change SSID name and enable encryption (use WPA-PSK, it's better), then check if laptop can see the new Access point with new SSID.
hi iv got a sitecom wl-143 wireless router and a phillips snb5600, both of which support wds, i have...
(More)
hi iv got a sitecom wl-143 wireless router and a phillips snb5600, both of which support wds, i have given both the routers te same ssid and they are on the same channel, they also have the same wpa2 key, one is a dhcp server the other should therefore pick up a ip for all computers connected to it. i have also added the mac addresses to each of the routers for the wds. how ever they will not connect. my computer connected to the second router (sitecom wl-143) sees the router as a gateway but it doesnt connect or give out ip addresses. any ideas?
no connection from router to computer,the computer says it connected but you cannot use wireless...
(More)
no connection from router to computer,the computer says it connected but you cannot use wireless still.tried alot of ways still not working.
I've attempted to find a solution for my problem on the internets, but cannot find any information...
(More)
I've attempted to find a solution for my problem on the internets, but cannot find any information anywhere. Anyway, my issue is that I need to change my NAT setting from Moderate to Open on my Netgear Wireless Cable Voice Gateway CVG824G modem.
My router works for 10 minutes and then doesn't for 5 minutes - any ideas? Sorry if I [posted this...
(More)
My router works for 10 minutes and then doesn't for 5 minutes - any ideas? Sorry if I [posted this twice but the router went down as I was sending it the first time!
