Question about Pantech Duo Smartphone
Battery problem my pantck dou runs out of battery .. in less than half an hour ..whats wrong with it. and it takes longer than usuall to charge ..
    Brigadier General:
  • 8,619 Answers
Take out the battery ,clean the contacts if it sitll gives the same problem ,try chargeing with a usb or another charger.
If still doesnot work then you need to get the battery replaced.
Do rate the solution .
Thanks
Rylee
Posted on Feb 07, 2009
Canon powershot a3300
If nothing is wrong with the camera, the battery is placed correctly, the battery cover is closed correctly then only one thing can be wrong. Even when you don't believe it is possible, the battery can be flat again.
So to make sure everything is as you think. Charge the battery again, and look if the charger acts as usually. The charging lamp turns orange and charging begins. When the charging is finished, the lamp turns green. Last time you charged, it could have taken 4 hours, before the lamp went green. If the battery is recently charged, it only will take a fraction of that time. If it still takes a long time, your battery was empty. It is recommended, to charge not longer than for 24 hours. After charging, please wait till the battery is cooled down. Then insert it again and close the battery cover. Check the cover closes correctly. And now switch on again.
If you charged with an USB cambs connected to the camera. Don't forget to remove the cable, because the camera won't start as long as an USB cable is connected.
Feb 25, 2014 | Cameras
Tip
How to make the battery life of a rechargeable electronic device last longer.
Have you noticed how the more you use a rechargeable appliance, the shorter it's battery life is? I don't know the exact reason, but what makes sense in my mind is that if you let the battery run out over, and over, and over, there is a little bit of the charge that you cannot recover and use, thus making the life of the battery shorter, thus giving you less time with the appliance. I have experienced this with my first Nintendo DS, which after letting the battery die over and over, would charge for hours on end and only last for a little bit more than half an hour. The way to stop this from happening is quite simple. I have a second generation Ipod, which i have had for about 3 years, and it still has almost full battery life. The trick is to keep the battery more than halfway charged all the time. The only, I repeat, the ONLY time you want the battery to run out is the first use. Yes, that is the opposite of what I just said, but it works. Trust me. I bought a new DS and used the same tactic, though i dont know if it was more than half a battery, and I have had it for almost 4 years, and the only thing wrong with it is the right trigger. I've dropped it several times on the trigger, and that is why sometimes it doesn't work. So, next time you buy a rechargeable appliance, keep this in mind.
on Jan 11, 2010 | Video Game Consoles & Games
I have a 03 saturn ion won't start. I replace battery and alt and starter and the car want say nothing unless I jump it off what's wrong
You may have a bad or loose connection or bad battery cable. Is the battery still charged up? If you have a voltmeter, check for 12.5 volts or more, then check for at least 9.6 volts when trying to start. If less, charge up the battery, or get a jump and run it for about half hour to recharge the battery.
Dec 01, 2013 | Cars & Trucks
The battery is not staying full it goes to 100% to 50 inless than hour
All rechargeable batteries degrade over time... Eventually it will degrade to the point where it will no longer hold a charge. Fortunately you can buy a better quality battery which will hold a longer charge, but it will be more costly than your original battery.
May 14, 2012 | Disney Netpal by ASUS Princess Netbook
My gateway M-7031U stops charging at 30%
Unfortunately your battery is probably shot. First though, try to run the battery down until the laptop dies. Now with the discharged battery, and the laptop powered off, plug it in and leave it off for a few hours. Power the laptop back on and check the charge level. Still at 30%? Then the battery is very likely just bad. Unfortunately, the cells in the battery just simply die for a number of reasons, and capacity is lost. This is why most manufactures will only warranty a battery for 1 year.
Take the battery out and write down the model number and the "MAh" or "Ah" number. The MAh number represents the capacity of the battery. The higher this number, the generally longer the laptop runs on battery. Go to http://gateway.shopbysystem.com/gateway-m-7301u-notebook-accessories.html and verify that this is your laptop model. This is a Gateway authorized reseller. Looks like they want $90 for a small battery. Take your battery model number and go to Amazon and look up the battery there. Make sure it's MAh number matches or exceeds what is on your battery. Usually you can get a replacement battery from Amazon for about $20 less than Gateway.
Oct 21, 2010 | Gateway M-7301u Notebook
How long does it take a hp pavilion dv60000 to charge
Exactly 8 hours for first charge in off mode
Sep 17, 2010 | Computers & Internet
How long should I charge battery for 12 volt Model
Those batteries should charge up in an hour, some maybe longer, but if takes longer than that, and they still don't charge, they are shot.
Feb 24, 2010 | Drills
Battery not running
Possible that whoever replaced your battery sent you the defective one back. Note the serial and model numbers on the battery, then request another one. When you receive the replacement, do a full recharge. Most new batteries come already half charged. Even in this state, take time to fully charge it (between 4 and 8 hours depending on the type and model). Then try running it on battery power. If the charge holds more than 2 hours on a new battery, youre good; less than an hour new, its defective. If after all of this still not resolved, request the company honor their warranty (usually a limited one year with purchase).
Mar 01, 2009 | Dell Inspiron Desktop with Intel Core 2...
Battery problem HP compaq nx7010
Could be memory effect. Have you tried letting the battery run out completely, and then recharging?
You need to set the power option in control panel not to turn off for low power, and just let the battery run out.
Or it could be a faulty battery. Have you tried another battery?
Oct 26, 2008 | HP Compaq Business nx7010 Notebook
Pantech Duo Smartphone Logo
55 people viewed this question
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
