Question about Sharp R-306LK Microwave Oven
I press time to cook and timer runs very fast and dings.
I press "clear" and shortly a message reads-"Sharp the best demo"
Everything else works.
  • Sharp Master
  • 9,086 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Posted on Feb 08, 2009
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
Tip
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual.
In Whirlpool/Kenmore models this is indicated by a lower case "d" on the right side of the display panel.
Most/All function except the magnatron (heat) work in demo mode so you can can learn to use the oven without actually cooking food
To clear "demo mode" press the "kitchen timer" pad and hold for 5 seconds until the "d" clears from the display... you may hear 2 beeps.
on Jun 16, 2009 | Kenmore 60654 Microwave Oven
Timer clock runs vary fast and will not heat up or cook anything
You have the unit in demo mode, Follow instructions in manual to exit demo.
Oct 29, 2013 | Amana UMV1152CA 1000 Watts Microwave Oven
The scrolling speed for the timed cooking is running incredibly fast - too fast to allow the food to cook. I was looking for a manual for Model #MV-1320B.
The owner's manual can be found here.
It sounds like the oven has been placed in "demo mode".
Nov 14, 2012 | Goldstar MV-1320W/B Microwave Oven
My Sharp microwave appears not to be working correctly. When I select the time to cook and press start the light comes on and the timer counts down, but it doesn't cook anything. It worked fine yesterday...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 21, 2011 | Microwave Ovens
Microwave timer counts down super fast
try unplugging it for about 15 minutes. if that doesnt work, you might as well get a new one. i fix everything myself for just the cost of parts and i have found that what parts cost for a microwaves, its cheaper just to buy a new one.
Oct 17, 2009 | Sharp R-540DK Microwave Oven
Sharp Microwave Oven Timer Counts Down Very Fast (Demo mode)
Here is where you can download the manual
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Yes the problem can be undone also.
Feb 09, 2009 | Sharp R-540DK Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Microwave timer going too fast
I had the same problem and found that the "demo mode" had been enabled. Turned it off and everything worked fine.
Nov 10, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
Sharp R-306LK Microwave Oven Logo
88 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
