Question about Canon PowerShot S1 IS Digital Camera
Lens will not retract
I purchased a new canon  power shot is March 29 05 at Wall Mart photo shop. The lens is will not retract . The problem occurred  February 6. Battery ok ; getting a message E 18. How  can I  fix the problem or how do  get it repaired ?
  • Canon Master
  • 4,738 Answers
Lens errors (E18 errors on some Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 10, 2009
Question about Canon PowerShot SD1300 IS Digital ELPH Camera
common problem ask the photo shop.
1- the powershot is set on when the battery is to low
then the lens will be blocked due to less current.
2-the lens is blocked bij a little tiny sandpiece.
Jan 24, 2018 | Canon Cameras
Was dropped. Now will do everything EXCEPT take photos. Lens, display, flash, etc. etc. all work fine. Just no screen image or photo when in "shoot" mode.
Sounds like the CCD or a stuck shutter blade. Try this place: www.CamerasAndParts.com They only service Canons and they are the only place we recommend for the Canons. It's all they work on and they are about half the price of most shops, plus the work is just excellent through them.
May 15, 2014 | Canon PowerShot SD800 IS / IXUS 850 IS...
Canon Power Shot A2000 IS lens is stuck in out position. I had to replace batteries. I replaced them and when I turn on, it says "Lens Error, Restart Camera" and it shuts offs automatically.
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 05, 2010 | Canon Powershot A2000 IS Digital Camera
My Canon Power Shot A1100 IS camera fell and now
There is no DIY fix for this problem, and attempting a fix is likely to worsen the problem and cause the camera to shut down. Sorry, but your situation calls for professional repair.
Oct 31, 2009 | Canon PowerShot A1100 IS Digital Camera
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
Flashing yellow light -- lens won't retract
Lens is jammed, you need to get it back on track. Gently push lens back in with a flat object to keep it straight, like a tabletop while powering it on. This may or may not work, but a jammed lens on these styles of cameras is common and renders the camera useless.
Dec 07, 2008 | Canon PowerShot A80 Digital Camera
Lens does not retract in play back mode
Never buy a Canon camera again. I have the same problem, and sorry that nobody has a solution. This is the worst of the 3 Canon digitals I have purchased. Lack of a view finder makes it impossible to preview shot when outside on a bright day.
Feb 23, 2008 | Canon PowerShot TX1 Digital Camera
CANON POWER SHOT
My camera lens has opened but will not close and retract.
Jan 17, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
70 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
