Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer not spinning
Light indicates it should spin but the clothes are still quite wet
  • bjetton Feb 10, 2009
    The solution was a little vague. I would like to have had maybe a range of possible causes of the problem from least costly to maybe the most costly. However, I did schedule a service visit.
    Scholar:
  • 99 Answers
This is a rather new unit, this unit is on a direct drive and I would advise that you get techn to look at it, it could be simple solution or quite costly according to what it is, could be several things, go to whirlpool.com and put in your model # and download your document and view the details on your machine, this may help you to decide.
thanks
joyce
Posted on Feb 07, 2009
Whirlpool duet washer not spinning clothes completely
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Washer.
Mar 24, 2017 | Whirlpool Washing Machines
Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Feb 16, 2017 | Whirlpool Washing Machines
Whirlpool code C:05
Have your Belt Checked on your Whirlpool most have belts that is hooked up to the washer and to a motor they can get worn and loose.
Mar 28, 2012 | Whirlpool GHW9300 Duet Washer
My whirlpool duet will go through full wash cycle and when it get to rinse it does full rinse but light for spin does not go on and it doesn't spin it stays in spin cycle (no light on) but it does not...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer is not spinning fast - so the clothes are more wet when done
sounds like washer is load sensing either overloaded or unbalanced when it decides to low spin insteasd of high spin dose it stop for second rotate 3 times and change direction 3 times the just spin slow.... if so either u have misloaded the machine by overloading orthe clothes are unbalanced in load may need add a towel or something to balance the weight evenly in the tub
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer spins but water does not discharge. spin
Tip machine back and remove the bottom panel, 3 screws. You will then see a large tube at the front, unscrew in a counter clockwise direction, and remove. Clean pin trap lubricate o ring and replace back into recepticle
Jan 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer won't spin
Sounds like the whirling noise is the pump, pumping. Does it drain at all? Check the drive belt and make sure that it is not broken. This system uses a drive belt with a clutch system to agitate back and forth. The clutch system could be bad as well.
This might not be a cheap fix, these are the main components of the system
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet Washer, clothes dripping wet
set it for a drain/spin cycle and watch it 12 min. doesit sound like the pump is kicking on???? if so is it removing water??? (you should hear it or see it exiting out hte drain hose.) next is it actually spinning at full speed by min 7 in the display it should start ramping up to the final full rpm spins, usually faults out if there a problem with unit itself, otherwise its a user end issue. you ARE usinf HE detergent right? not just a little less of regular soap! although it sounds good HE detergent actually designed for yuse qith the frontloading products, too much suds causes , no hide speed spin aas well as a SUD in the display
Mar 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
67 people viewed this question
Dan Webster
Dan Webster
Sal De
