Question about Hotpoint Aquarius WF210 Front Load Washer
Washing machine noisy when spinning
Hotpoint aquarius wf210 sounds like it's got rocks in the drum when on spin
  • smiffy1496 Feb 10, 2009
    same problem but just on spin. sounds like something stuck between outer and inner drum.sounds like a rock stuck betwwen drums
    Scholar:
  • 99 Answers
This is joyce
you have got bad barrons in drum, they need to be replaced they will cost about $80.00 to buy and about 1 hour to replace by techn. if you do it yourself you need to go to ge.com and put in your model # and download your document and that will show you how to get a breakdown of your machine, this should help
thanks
joyce
Posted on Feb 07, 2009
Hotpoint pump
Is the machine not spinning? May need new bushes. Sited underneath and wear down by making contact on drum.
Feb 05, 2012 | Hotpoint Aquarius WF210 Front Load Washer
Washing machine sounds like a jet plane, when spinning
I would suspect that the main drum bearings have failed.
From the front of the washer, spin the drum by hand, and if it feels rough or is noisy, then the bearings have failed.
There should be little or no noise when you spin the drum.
Jan 31, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Very noisy when spinning
hi
it may be the belt making noise,,,check it,,,
thank u,,,//////please rate it
Jul 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
The water wont drain or spin wf210 hotpoint
Hi I think your problem is that the filter is blocked, filter is located between drum and pump at the rear, clean that out and that should solve the problem.
Mar 08, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Started having a noisy rinse & spin cycle, then stopped.
Open the washer door and spin the drum by hand, if it feels rough or noisy and rumbling, then the main drum bearings have failed. There should be little or no noise when you spin drum
This is a major repair, and I would not recommend a D.I.Y solution.
Other possibility is there is something in the pump, but you would only hear this when the pump is working.
Plz rate my comments.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Water stil appears in drum even when machine is turned off
It is possible that you have a bad water valve. Turn off the water when the machine not in use if the problem stops the water is probably coming in through a defective valve.
Hotpoint WF620 - flashing error F05
This is a drain problem. Most likely something caught in the pump which is accessed by removing the small panel at the rear/bottom of the machine. The pump slots in place and can be removed by lifting and shifting to the left. Unscrew the pump off or remove the pipes will reveal all.
Dec 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Bearings very noisy on the drum
aquarius w f 541 1400 spin drum bearing noisy
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Jan 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WF210 Front Load Washer Logo
208 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
