Question about Visioneer XP100 Strobe Mobile Scanner USB
Visioneer Strobe XP 100 - Vertical lines on photos
My Strobe XP 100 sheetfeed scanner will scan documents fine but when I scan any type of photo (i.e. old, new, b&w or color) I get vertical lines. I have calibrated and cleaned the scanner but I still get lines on the photos. I am hopeing that someone out the has had the same problem and knows how to fix it.
I lost my software Driver of Flatbed scanner D1250u2f. So, I want to download a new for my scanner. Where Can I get it; can you help for getting it.
Posted on Feb 08, 2009
When feeding the visoneer strobe xp 470 with more than one sheets of documents, the first document goes through with no problems, however, the remaining documents goes through at a faster rate (without...
hi this could be a driver error, try updating the drivers for this, if not un-install the drivers and re-install them and that should sort it out ...hope this helps
Oct 27, 2010 | Visioneer STROBE XP 470
Loaded Visioneer Strobe XP 300 with PaperPort 11 on Win7 machine, but all scans come out black. Any ideas out there? Previously I had the same scanner working fine on an XP machine. Maybe there is an...
Did you calibrate the scanner on the Windows 7 machine? When you calibrate, a file is saved on the host computer - if you do not calibrate, everything is black.
In case you dont have a calibration sheet, I just uploaded one to FixYa - it will take a few days for moderators to review it, but then you can print it out on both sides of a single sheet of paper (so that the arrows are pointing at the same end of the paper, but on both sides of it) and use that to calibrate your scanner - make sure that you have 'edge to edge' printing turned on, as there cannot be any white space on the sides of the black space.
Aug 22, 2010 | Visioneer Strobe XP 300 Pass-Through...
I do not have an install disc
http://support.visioneer.com/products/XP100/downloads.asp
check your part number against what's on the website to get your driver.
Oct 25, 2009 | Visioneer Strobe XP 100 Path-Through...
When I scan 4x6 photos there is a line (sometimes green) across the entire photo that used to not be there. Scanning larger 8x11 photos the line does not show or when scanning documents. Help! I'm in...
If line is vertical.
Try scanning a bigger document. Use a blank page big as the scan capacity and scan the blank page.
If for example you are using an a3 scanner, scan a blank A3 page.
When scanning blank page set resolution to an high value, so that you does not lose pixels.
Check scan result, and explore the whole document using zoom to see if the line is still present on the test scan of the blank page.
If there is still the line, then it is either a scanner dirty, probably inside glass, or a dafective sensor on CCD sensor array.
If there is no line, then the problem is usually depending on the software.
In that case uninstall the software and install it again.
If that is not enough to fix the problem, try uninstalling software, doing a system restore to a date before the problem started , and then installing software again.
If the line is horizontal , that is usually a loss of power on the high voltage to lamp.
Try reinstalling software first, if that does not fix the problem , and line is horizontal, then it is fault mentioned above.
Horizontal lines at the end of a document may also be caused by faulty scanner control board, or scanner going out of memory.
Oct 10, 2009 | Fujitsu Office Equipment & Supplies
I have vertical lines in my photos when i scan them
If the lines are in the same location for all scanned outputs, it is clearly dust on the scanner glass. Clean it thoroughly.
S. Mohan, India
Jul 04, 2009 | Epson Perfection V350 Flatbed Scanner
Vertical lines like wallpaper on my photos
you should try to clean the glass on your scanner.or clean the printer ink heads.
Dec 22, 2008 | Visioneer XP100 Strobe Mobile Scanner USB
VISIONEER STROBE XP22 SCANNER
WE DID NOT HAVE A "CLEANING SHEET" AS WAS SUGGESTED BY THE MAKERS OF THE VISIONEERS. APPARENTLY OURS DID NOT COME WITH ONE UPON PURCHASE. HOWEVER, WE WERE SUPPLIED WITH A CALIBRATION SHEET. WE SIMPLY RAN THE CALIBRATION SHEET AGAIN ...... PROBLEM SOLVED.
Nov 07, 2008 | Visioneer Strobe XP 200 Path-Through...
Horizontal line appears in scanned document
open the scanner and remove the clips, move the lense up and clean it. it is very easy to clean.
Feb 13, 2007 | Visioneer Strobe XP 200 Path-Through...
Visioneer XP100 Strobe Mobile Scanner USB Logo
352 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
Sanath Kumar V
Clive Gray
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
