Question about Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch
Battery change When I depress Adjust button I get a diamond shape in front of OPEN and CHECK.  What should I do?  What did I forget?
  • Anonymous Mar 21, 2009
    What a selfish guy! Keeps the solution for his own!!!
  • Capvermell May 11, 2010
    Why are you keeping the solution to this problem a secret. You should have said what the solution was that was given to you by another member of this group.
I received a message from a member of the group suggesting a solution to the problem.  I followed his advice and the problem was solved.  My thanks to him and to the group for the assistance.
Now I need a manual for the Casio CBX-102.  This will be a gift to my grandson who is attending college and needs to understand how to use the Data Bank.   If anyone can suggest a source for the CBX-102 Data Bank watch I'd appreciate it.
Thanks to all,
Bill D
Posted on Feb 09, 2009
Have a 4 button Timex Expedition (Indiglow - 100 meters). The lower right button no longer works so I can't change settings. Recommendations?
Take the back off and examine if the pin from the button is still able to depress the switch or if it's clogged up with debris.you should be able to depress the switch with a sewing needle to adjust from inside the watch.be careful not to lose the screws off the back.good luck.
Apr 12, 2015 | Timex Watches
Can i get an extra link for my tissot 1853 (prs 200) bi metal,the strap is to tight, and will not adjust anymore.
I need one link for my watch that was given by my daugther its tissot diamond t shape stainless steel case,mop dial
Oct 26, 2012 | Tissot T Touch T33158851 Watch
MICHELE CSX HAND ALIGNMENT
You don't say if your "CSX" is a battery powered watch or a mechanical or windup type watch. The solution for a mechanical watch is take it to a watchmaker. If it is a battery powered watch you may be able to do it yourself. Not all work the same way so without knowing what a "CSX" is I will give you one way to try. Pull the crown out two clicksHold the lower button in until a hand moves.You have now selected that hand to adjustUsing the upper button now, press and adjust the hand until it lines up with 12Now hold the lower button againAnother hand should moveUse the upper button to adjust this hand to the 12 positioncontinue this until all the hands line up with 12Press the crown in and press the upper button,the chronograph hands should startPress the upper button again and they should startPress the lower button and they should all go to the 12 o'clock position
Oct 21, 2011 | Michele CSX Diamond watch
I want to change the batterys but unable to open the back it is diamond shape
if you cannot open it, just bring it to watch service center because they all have the tools for opening and closing your watch. and to avoid much problem. i hope i had been helped you,
Aug 13, 2011 | Kenneth Cole 1213 Wrist Watch
I have a geneve quartz 14k gold mans watch dont no how to take apart to put battery in.
mcdevito75 here, Battery usually lasts 1 year and longer, even if you did change the battery yourself now, you"d forget for a year or even longer next time battery needeed to be changed, I know I did. Add to this you can easily destroy your watch with in-correct handleing. BEST BET, look for a small watch repair shop in your area for this battery change $10--$15.00 and peace of mind.
Oct 26, 2010 | Geneve 14K Gold Ladies Diamond Panther...
I have a Series 118 Pierre Cardin Quartz alarm with 3 buttons: Light, Set and Mode; I can't figure how to set/change the time
mcdevito75 here, The mode button is the button you need to depress to set the mode of the watch. Depress the mode button once, see if anything on the face is blinking, if it is use the set button to adjust the time/date You may have to depress the mode button twice or depress and hold down the mode button a couple of seconds to get the face/display of your watch to blink, after you make 1 adjustment to move to the next depress the mode button again until you get to the next adjustment, or the next function to set on your watch. After you"ve set all the functions depress the mode button again to stop the blinking a show a steady display.
Jun 12, 2010 | Watches
Change military time to standard time on a Casio e-data watch
Depress the recessed 'Adjust' button (top left side) which will get the time setting flashing. Then depress the button on the lower right side once to get to the 24 hour time option. You will then have manually enter the time in that format. Once set, then depress the rescessed 'Adjust' button again.
May 21, 2009 | Casio E-DataBank DBC3101 Wrist Watch
Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Oct 30, 2008 | Kenneth Cole RK5034 REACTION
Kenneth cole reaction
Jul 16, 2008 | Kenneth Cole RK5034 REACTION
Casio Triple Sensor Pathfinder PRG60-1AV Wrist Watch Logo
253 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
