Question about Black & Decker Cordless Handi Saw
HOW TO INSTALL BLADES
How do I install lades?
  • 2,176 Answers
OK just looked at manual for the CHS6000 handisaw and there is a lever on the front that you need to press down on fully and insert the blade from the front and then release lever and it should lock. This tool from what I saw can take the T shank blades or standard ones. If you still have trouble I would go to Dewaltservicenet.com and in the middle of the page towards the bottom you can type in your model number and either read the manual online or print out a copy. This manual is 34 pages long. Let me know if you still have problems.
Posted on Feb 08, 2009
How do I install the saw blades
Install the saw blades on what? Make & Model please
Jan 11, 2018 | Saws
I have Z445 54 inch and the middle blade. Is cutting lower than sides. The outer blades are at same height, any help?
Middle lade has probably hit stump and bent. Try moving to outer and see if this does not move problem. If you still have problem at middle look at the blade spindle bearing could have gone bad and shaft dropped.
Aug 05, 2017 | John Deere Garden
It will not engage the blades when the switch is pulled
When you engage the lades it usually consists of a loose pulley being drawn tight so that the blades turn. If they are not turning, either the belt has broken or it has stretched and needs to be adjusted or replaced.
Jun 28, 2015 | Garden
How to install blades
What make and model saw?
Jun 26, 2013 | Saws
Can I use Craftsman 99-3/4 in. Band Saw Blades - 3 pk. on my craftsman 14" bandsaw #124.32607
I think you need a specialist to answer your questions and can give you some options. You may want to give a call to www.sawblade.com . You can contact this 201-450-9810 or visit to their website . Hope that helps.
Dec 27, 2012 | Saws
Blade adjustment for dewalt dw733 planer, installed new blades and I have the knife guages that comes with the machine but not sure how to adjust knife blades
go to dewaltservicenet.com and you can download an owners manual with instructions on how to adjust/install the blades.
Jun 14, 2011 | Tools & Hardware - Others
Cd lade sluit meteen nadat deze is open gegaan
Hallo,
De lade heeft een eindschakelaar die de motor uitschakelt als de lade uitgeschoven is.
Wellicht is deze defect of smerig.
succes,
Gerard
Mar 21, 2010 | Audio Players & Recorders
Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Jun 30, 2009 | Ariens Garden
Reassembly of trimmer blades to motor body
Put the ware plate on the support bar.
On top of that install one blade facing up.
Then install the other blade facing down.
Put the bolts up through the support bar
Install the little rubbing blocks on bolts in slots in blades.
Place top stiff plate on top and install nuts.
Replace grease in gear box with stihl hedge trimmer grease onyy
Mar 19, 2009 | Garden
Printer not print/Don't understand language so can't fix
find your manual in your language here and follow language setup instruction to your display in your language
Jan 26, 2009 | HP LaserJet 4050n Printer
Black & Decker Cordless Handi Saw Logo
578 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Ruben Bustamante
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
