Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool lsq8543jqo spin cycle not working properly
Well, here seems to be the problem. Our washer goes thru all the cycles except the final spin properly. On the final spin, it makes a rubbing/grinding type sound and the basket is only moving about an inch then stops then moves alittle more then stops again, kind of like when its agitating. I have no clue about how to even start trying to troubleshoot this.
  • K9 lover Feb 21, 2009
    I have the same problem with my washer must be a problem with this model. Not all the time but especially with heavy loads at the end of the wash cycle I go to move them to the wash and they did not spin out at all. The items are soaking wet. My repairman said it would be too expensive to tear the washer down and by the time you pay him for labor and part you could just about replace it. I am now looking for a replacement b/c now the agitator has quit working during the wash cycle.
  • 25 Answers
Check the inner tub block.
Posted on Feb 18, 2009
Whirlpool cabrio (4yr.old) making loud motor straining noise on final spin cycle.
Hi valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Valued Consumer), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool WTW6400SW Cabrio Washer
Will not spin
The final cycle of any washing machine, including Whirlpool units, is the spin cycle. During this cycle, water is sucked out of the load, preparing the clothes for the dryer. If your spin cycle isn't working properly, your clothes will be extremely wet, which increases the length of the drying process. Troubleshoot, and repair this problem yourself to save money
Jul 29, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothes seem too damp after final rince
its a washer ,not a dryer....if the spin setting is set low the clothes will feel quite wet....reset to a faster spin cycle if needed.
Jul 26, 2010 | Whirlpool LSQ9549P Top Load Washer
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
Whirlpool Washer Stop Working after Agitate
Good day,
If it goes thru the wash cycle normally then quits, it is the lid switch assembly.
To remove the top console, be aware there are 3 locations for the screws. Bottom left and right. Bottom left and right but covered by plastic end caps that have to be unsnapped, and finally, bottom rear.
There are also 3 different lid switch styles, so use the complete model number or take the old one in to the supply house.
Here is a good tutorial on the change out procedure.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Mar 05, 2010 | Whirlpool Washing Machines
Kenmore 110 Spin Cycle
Assuming that this is a basic top load, direct drive, neutral drain washer it seems as if the problem is likely in the timer.
The transmission and draining are controlled by the motor which gets it's power through the timer. If the timer isn't advancing once it gets to the spin cycle area, the motor keeps getting power, the machine keeps spinning and only by pushing in the control knob will the motor stop.
Here are a couple of places to look at how the machine works and parts for a basic Kenmore washer.
Sears parts site:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a number of sub catagories for the washer components.
Whirlpool Installation and maintenance PDF.
This is a public domain Whirlpool manual describing how the washer works and a good troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sep 21, 2009 | Kenmore 22642 Top Load Washer
Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
No final spin
I haven't experienced that problem, but is it possible that the machine becomes unbalanced with the spinning load and then aborts the spin, so it doesn't finish? Has the machine been properly leveled during installation?
Apr 09, 2008 | Malber WD1000 Front Load Washer/Dryer
Washer won't start spin cycle
sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
443 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
