Question about Whirlpool Duet GHW9150P Front Load Washer
Cant get door open
Put macine in drain spin think pump bad or stoped up
  • lhammer Feb 08, 2009
    I have a front load washer... I am having the same issue... When I press power and wait a few seconds before pressing start it beeps 3 times. I have tried unplugging for several hours, checked breaker, pressed cancel button.. pressed every button on front. Door is locked and I can't open... Any suggestions?
    Scholar:
  • 99 Answers
This is joyce.
I am not sure what is going on with this unit but try this first unplug unit from wall and try to reset it and see if this will let you open the door, if not you will need to call whirlpool to get help. go online to whirlpool.com and get their # or their website is whirlpool.com
thanks
joyce
Posted on Feb 07, 2009
Run diagnostic test gltf2940es0
if the drain pump is bad or clogged and can't drain the water it won't spin until water is drained.pump number 137221600,it's around 110 dollars,but first get a shop vac,pull out the drain hose from the washer and connect the shop vac to the hose and vac out all the water,you first have to remove the bottom front panel to get at the pump,remove the hoses going to the pump and have the vac ready to clean up any water that still might be in there,then check the pump and see if anything is in there,i've found coins that get into the pump or other debries and clean it out of the pump,then check the rubber boot on the hose,make sure nothing is in there and check the other hose,you can set the shop vac on blow and blow through the drain hose to make sure that's clear,remove any junk you find in any of the hoses and pump,reconnect the pump and hoses,put some water in then set it to drain and spin or rinse and spin,if the water drains and then it spins you're all set if not the pump could be bad,one more thing if the drum doesn't move you could just have a bad door switch,this is the easiest part to fix and i always have a door switch for frigidaire washer,remove the spring the holds the boot seal on.remove the rubber boot on the door switch side,take out the screws that hold the door switch in,and replace it,run it,if the drum starts to move then drain and spin it was the door switch,any error codes come up? good luck,have any questions let me know and hopefully i can help you
May 19, 2014 | Frigidaire ATF6000ES Front Load Washer
Hotpoint aquarius 100 wm62
tha model number doesn't come up,you need to send the full number off of the washer,open the door and lok around the opening where you put the clothes in,you should see a tag with the model number on it,if the pump doesn't drain out the water then it can't spin until the water is drained,if it's a front load washer check the pump to see if something is in the pump stopping the impellar from spinning to drain out the water or you could have a bad pump,put the washer or drain and spin and see if it will drain.
Jun 06, 2013 | Washing Machines
Washer will not spin
Post back with the model number, there are different drive systems.
It can be a bad door switch, if the machine does not think the door is shut, it won't spin.
Could be a bad belt, if it has a belt.
Can be a bad timer on the control panel.
If your model has a drain pump and the gate valve does not open it won't spin.
This is why you post the model.
Apr 03, 2013 | Washing Machines
BASKET WONT SPIN TO DRAIN
Check the lid switch could be bad or have a bad connection. The lid switch is to keep it from spinning with the door open. If it won't drain it won't spin it may have a hose blocked or the pump is not working. Check if the motor runs after it agitates. If it does is the pump turning? Check all hoses , from tub to pump, from pump to drain, check for sewer blockage. A sock or something could be in the hose from the tub to the pump, or in the pump not letting it drain. If it is agitating the coupler must be ok. Hope this helps.
Dec 23, 2010 | Whirlpool Washing Machines
Washing macine won't drain.
Door switch problem. The switch is either cracked or broken and not registering as closed. If the unit is most likely also not spinning too.
If the unit DOES in fact spin, then the hose is kinked or clogged. But i believe it isn't spinning too.
Replace the door switch.
Mar 14, 2010 | Whirlpool Washing Machines
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
Door would not unlock - got an error code f-22 what does that mean?
your door switch may be going bad.try pushing the door in and hit drain spin and if that works then it will unlock.I need to know what code is flashing to help further.hope it helps.
Mar 05, 2009 | Whirlpool WFW9200S Front Load Washer
Whirlpool Heavy Duty Super Capacity Plus not spinning
HI thanks for the question . On your model thers is no belt it is a direct drive.IF the washer stoped pumping the water out in pump out then your problem is with the lid switch. The lid switch is located under the top Thanks for your question hope this helps you ,THE appliance doc
Sep 10, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer not spinning or draining
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Draining
if you select drain spin and you hear the pump running then check all the hoses for blockage if you dont hear the pump running then make sure your door is locking
Jan 19, 2008 | Maytag Neptune Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
41 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
