Question about Shure E4C Consumer Headphones
Shure E4C headphone failure
Usually it's the ground wire feeding into the earpiece that fails. The soldered connections on the driver are usually good. Shure charges $109 plus shipping to repair E4Cs that are out of warranty. I expect that they just replace the earphones with an enitirely new set.
I just repaired two sets of E4Cs that I have. I managed to open the earpiece, unsolder the connections, re-strip the wire, flux and solder and put on new shrinkwrap protection on the cable. They're not cosmetically perfect anymore but they work prefectly.
  • Anonymous Mar 19, 2009
    Cool. How do you open them? Thanks.
I just found out how to open the E4's.
What you do is, unscrew the metal cap that holds the angled earbud tube in place. Note that the tube itself can't be turned.
Then remove the metal ring behind it as well as the small rubber ring.
There is a 'hinge' at the cord end of the earbud, so what you should do is take a very sharp knife (I used a scalpel) and pry the top off the earbud from the end that had the ring mounted by inserting the knife between the top piece and the metal element. Note that it's attached with a little glue, so it will take some coaxing to get off.
Posted on Apr 02, 2009
My dell latitude d510 internal spk is ready but output headfone jek not working
these are fairly passive in that if a headphone or earpiece is plugged in, they switch the output from the internal speaker to the external speaker. So, it's usually one of a few problems.
  • The jack is mucked up, and needs replaced.
  • The headphone plug wires have a broken connection
  • The headphone needs power to amplify, and that's not working.
If trying another headphone or earpiece you know is working doesn't work, it's the jack itself. They can only handle so many uses before they either fail closed, or open or completely. Depending on which one, either:
  • neither speakers nor headphones work.
  • only speakers work
  • only headphones work
Replacement necessitates opening the case and replacing the jack. For that, there's no help.
Sep 02, 2015 | Dell Latitude D510 Notebook
Replacing minijack
I use a multimeter to check the connections to the ear pieces. I set it to the diode function. The meter's test probes also have a very low dc voltage and this causes a 'click' sound in the working earpiece. Some earphones have 3 wires, others have 4 wires. In the 3-wire setup, one wire is the common wire. It goes to the ground connection of the mini plug. The 'click' sound on the left ear piece should go to the tip of the connector. The 'click' sound that you get on the right ear piece should be soldered to the 'ring' of the mini plug. The 4-wire type of earphone/ headphones cable usually have two wires that are the same colour. These are the ground or common connections for both right and left. I hope that this helps. A multimeter or vom is a necessity. Len.
Apr 11, 2014 | Klipsch Image S4a black For Android In-Ear...
I WHICH TO PURCHASE SOME HEADPHONES FOR SRF 59
follow this steps and fix it. God bless you
    • 1
Locate the faulty connection along your cord. Plug in your headphones and play sound through them as you jiggle the cord at various points to locate what part of the cord is cutting in and out.
    • 2
Cut the cord using wire cutters an inch or so past where the fault in the cord is. If this is at the connector, cut the entire connector piece off. If it is near the headphones, cut off enough to eliminate the faulty section and still allow the cord to be reconnected.
    • 3
Strip the end of the cut cord. There are three wires in the cord: the left channel, the right channel and the ground. The left and right normally are colored, and the ground is bare.
    • 4
To repair a poor connection where the cord meets the headphones, match the wires with the correct leads coming from the earpieces and twist them together. Wrap the wires with electrical tape.
    • 5
To repair a bad connection at the connector jack, acquire a new 1/8-inch connector and attach the cord's inner wires to the appropriate points on the connector. Connect the left channel wire to the tip, the right channel wire to the ring, and the ground wire to the sleeve. Solder all the wires in place.
    • 6
Connect the headphones to a sound source and test for proper function. Jiggle the cord at the new connection to make sure it is secure and does not cut in and out.
Oct 27, 2013 | Sony Audio Players & Recorders
My technics headphones have just stopped working, is it probably a faulty chord?
Unusual to fail on both channels at the same time, however the most common cause is a break in the wire just above the 3.5mm plug.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Technics DJ Headphones
I'm trying to repair the jack of the headphone that I have. I spoke with a guy from Radio Shack and he says I will need to solder the wires to the positive and negative area of the after market male jack...
There should be three solder points on the jack if it is stereo and two if it is mono. The middle points are the positive and the outer point is the negative. The positive wire from the cord is usually the colored wire and the ground or negative wire is usually the black or bare copper wire. You will probably have two colored wires because of the left and right connections to the headphones.
Feb 20, 2011 | Audio Players & Recorders
One ear bud does not have full sound, i think it might be ear wax any way to safely clean with out damaging the speaker?
This is caused by microscopic wax build up in one ear. You'll probably have to send the earphones to Shure for replacement.
Sep 29, 2009 | Shure E4C Consumer Headphones
Damaged/broken earpiece cabel
if you have a soldering iron, this is easily rectifiable.
any electronics repair store, or even the manufacturer could do this for you
Mar 21, 2009 | Shure SE530PTH Professional Headphones
Losing sound in my Shure ear buds, they are one year old.
the wire breaks after a while in ear buds ,and head phones due to the constant flexing,and moving.they probably need to be remade.by cutting out the bad part of the wire(usually close to the fitting)You can usually wiggle the wire and find where the breaks are that way.it can be a real pain re soldering ear buds.also check the plug end by wiggling the wire there.
Mar 16, 2009 | Shure SCL3 Headphones
Not able to hear songs properly in sansa e250 mp3
I am not familiar with this particular player, but this problem is usually caused by the headphone socket ground connection,
If the ground connection is lost then the right channel grounds through the left and vice versa.
If you can dismantle the player, check and re-solder the headphone connections. If this doesn't work solder a thin wire to a ground point on the PCB, then touch this to each connection of the socket in turn until the sound is restored. Solder the wire to this connection, and re-assemble the player.
WARNING : make sure that you have made the connection to ground. A live connection could damage the player.
Feb 29, 2008 | Audio Players & Recorders
Shure E4C Consumer Headphones Logo
1,649 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
