Question about Brother MFC-5440 Printer
Scanner will not work
The printer works, and so does the fax. I have re-installed and it has not helped.
    Sergeant:
    Champion:
  • 357 Answers
Some machines have a scanner head lock to prevent damage when moving the machine, see if your machine is one of them and unlock it.
You may need to calibrate the printer and the scanner.
Good Luck.
Posted on Mar 16, 2009
How do I install the scanner. I installed the printer, it works but the scanner and fax did not.
You need to install the drivers for the scanner and fax. They are separate installs. They should be on the CD that came with the printer. You can get them from Cannon's web site too.
Dec 04, 2014 | Canon PIXMA Office Equipment & Supplies
I cannot receive fax on my dell940 printer. help
The A940 is not a standalone fax machine, and needs to work with your computer to send and receive faxes. Your computer needs a dialup modem installed and a connection to a phone line, and you need to have fax software installed. The printer actually only works as a scanner to input a document to be faxed, and as a printer to display a received fax. The installation CD supplied with the printer has fax software on it you can install, and other software is available online. This document from Dell (the fax section of the user's guide) may be helpful.
Jul 29, 2011 | Office Equipment & Supplies
Problem with fax, when fax is turned no it read scanner driver not working. can you help.whenever a fax is sent we don't come through you can hear it dialing fromthe other end that all tried to install new...
scanner drivers have not been properly installed .it requires fresh installation of software after removink previous install of software. tell me ur operating system,i will give you steps to uninstall previous software and install new software.as far as fax is concerned,first we have to install drivers,then ur fax issue will be solved
Aug 17, 2009 | Office Equipment & Supplies
Scanner not working
Hello
You will probably need to install "HP image Zone" software from hp s website here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=1147936&
Aug 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanner says I need to install software
To make your scanner work use HP image Zone (included in your install cd or downloadable from hp's website)
Hope this helps
Jun 27, 2009 | HP Photosmart 2610 All-In-One InkJet...
Lexmark series x2350 all in one scanner does not work.
Is the scanner driver installed ?. You can check this by unplugging the USB cable from the back of the printer and connecting it again. If you get any Plug and Play prompts on the computer, install the driver by pointing it to the correct scan driver location.
May 27, 2009 | Lexmark X2350 All-In-One InkJet Printer
Cant get scanner or fax to work in all in one
1st u install the drivers n for fax check ur tel line
Jan 27, 2009 | Sharp AL-1661CS All-In-One Laser Printer
I just got a new Dell Windows Vista Laptop. I currently have a Brother 7420 printer, fax, scanner, copier combo. I can't get the scanner to work. Please HELP... Thanks, Pam
I presume the print and fax parts work. Can you make a copy? Have you checked the driver software? The CD that came with the equipment usually installs the scanner software as well. try reinstalling the software and see if it works.
Dec 01, 2008 | Brother MFC 7420 All-In-One Laser Printer
Scanner doe not work,fax and print are ok
first re-install product driver properly then try.
Jun 03, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Scanner quit working
the scanner works with the windows built in driver. Uninstall the hole mfc suite and reinstall after restart. This is the fix for the software. You can check the hardware simply by copying a page. If you can copy there is no hardware prob. Post here again if it does not work and let me know your windows version, too, please.
Sep 29, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-5440 Printer Logo
175 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
