Question about Samsung RS2556 Side by Side Refrigerator
I have a samsung rs2555sl refrigerator not working properly
The unit isn't stay cool in the ref and the freezer isn't freezing. it also has a huming noise. the freezer is reading 61 and the ref is reading 41. I have an rs255sl refrigerator. It stopped cooling. I defrosted it manually by opening up the plastic cover inside and found a ton of ice among the grids. Somehow the defrost stopped working. After the ice was removed, the first fews day it resumed working. But about 1 month later, the inside temperature rose again. Also it makes noise. My conclusion is that the problem is its defrost. The question is where I can get the defrost parts.
vanni7
  • 163 Answers
SOURCE: SAMSUNG REFRIGERATOR MODEL SR-368 freezes and no cooling.
Hi!!! You have a defrost problem.You need to change the defrost timer mechanism.In Samsung frig the defrost timer is in the main pc board..Good luck..
Posted on Jan 05, 2009
  • 825 Answers
SOURCE: my side by side Samsung
I guess the freon gas is not circulating properly on the cooling tubes...check for any blockage or damage in the cooling tubes...
Posted on Jan 23, 2011
woodchuck789
  • 4070 Answers
SOURCE: Fridge side affected, not freezer. Unit stops
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Post your model number for more specific information.
Posted on Mar 25, 2011
walesarumi
  • 6993 Answers
SOURCE: I have a Samsung RS267LBSH, which is a
When the fridge side is getting too cold or icing up, this is because the control of the compressor has gone bad in some way...
There a few different things that could cause the unit to lose control over the temperature of the fridge side.
If your refrigerator has a damper door that opens and closes to allow cold air to move to the fridge side the damper linkage or the damper motor may have broken or gone bad.
The coils in your fridge may have frozen over and now the air does not move at all so then the ice builds up and can freeze parts of the fridge side.
The thermostat has gone bad and so now the compressor runs continually. This will not be noticed readily on the freezer side but will show up quickly on the fridge side.
Many newer model refrigerators use an electronic sensor or thermistor to read the temperature and supply the info for the circuit board and often a digital readout.
So, here is how I would go about troubleshooting this problem.
Check the coils for ice, defrost the coils with a heat gun or hairdryer, then check for the reason why they iced over. Defrost control or defrost timer bad? Evaporator fan bad?
Check the damper door to see if it is stuck in the open position. If it is then check the motor and the linkage.
Check to see if the refrigeration unit will shut down if the thermostat or digital setting is turned up to a higher temperature. If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or control board.
Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of adjustment in the thermostat or setting of the temperature will not solve your problem very simply.
I hope the above helps.
Good luck.
Posted on Jul 18, 2011
  • 500 Answers
SOURCE: My Samsung RS2534 side by
Hi mminottoi2004,
It uses a defrost element, built into the evaporator to melt the ice once every 1 - 2 hours. I suspect one of the sensors are failing, or the defrost element is faulty or worse.
You can test the defrost element with a decent multimeter, make sure power is getting to it, in at least 1 to 11/2 hours. If no power ever reaches the element, even when the compressor shuts off, then more likely the problem is the PCB. If power does reach it, but it does not get warm, the defrost emelent needs replacing.
Testing sensors on Samsung models are nearly impossible, so I am not even going to advise it. The resistance readings never make sense.
So in a nutshell: 1) Faulty Defrost Element or 2) Faulty Sensors or 3) Faulty PCB.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Posted on Aug 15, 2011
Freezer side seems to work but the refrigerator side isn't
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Sep 11, 2011 | Maytag Refrigerators
40 TO 50 DEGREE IN SIDE REG/ FREEZER 32 DEGREE IN FREEZER. HOWEVER CLEANNING RESET DAILS BRING US 10-0 DEGREE FREEZER/ REF 32-38 DEGREE IN REF. THIS REF WILL NOT SABLE ITS SELF. WINTER TIME NO PROBLEM/...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Hotpoint Refrigerators
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
I have a samsung RS2555SL the fan does come on and the refrigator side is not cooling the freezer side is cooling.
It sounds like you have a iced up evap in the Fresh Food side so You need to clean all the ice near the top light and all from all the places.
Appart from this you should also get the thermistor checked and the frig fan. Doing this will fix the problem.
May 30, 2010 | Samsung Refrigerators
The digital display on my rs2555sl Samsung stopped working and the fridge and freezer are not cooling. The fridge is only 4 years old. what could the problem be?
circuit board controling temp to both fridge and freezer is out. Could have been fried by an electrical surge or just a badcircuit board.
Sorry
Dave
Jan 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
My samsung ref rs2555sl stopped cooling. The temperature display for both freezer and fridge on the front keeps flashing. What do I need to do?
Most of the time if you unplug it from the power source for about 10-15 minutes will reset fridge computer and when you plug it back everything get back to normal.
Oct 02, 2009 | Samsung RS2578BB Side by Side Refrigerator
Jenn Air ref/freezer not freezing/cooling
Take the back out of the freezer and check and see if the refrigerator is in defrost while it is cooling if it is replace the timmer, then check and see if the fan on the underside is working if not replace the motor this will cause the problem also.
If all that is ok feel the small line under the refrigerator ( high side) and see if it is hot while it is running if not check the freon in the refrigerator.
Mar 03, 2008 | Refrigerators
Samsung RS2556 Side by Side Refrigerator Logo
183 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
