Question about Audiovox NPD5500 GPS Receiver
Audiovox NPD 5500 car nav
How do I adjust screen dimming? I believe the control is in the "Monitor Settings" screen, but I don't know how to get there. Not addressed in owner's manual.
3 Suggested Answers
wn3six
SOURCE: the screen on my Audiovox FP1510 has gone dark
Most likely you have a bad INVERTER module, this module supplies high voltage to the baklight assemble which is likely why you can only see a very dim display on your LCD TV. The inverters are relatively cheap. Hope this helps ! Good luck..
Posted on Oct 18, 2011
jasenhinds
  • 15 Answers
SOURCE: owners manual audiovox dual 7" mobile dvd player
http://phone.manualsonline.com/manuals/mfg/audiovox/audiovox_telephone_product_list.html
Posted on Apr 03, 2012
Display screen on sat nav system dim
you must return you car to the store where you buy the sat nav, for update and revision again. something is missing or bad installing.
God bless you
Jul 05, 2013 | Cars & Trucks
I would like to know how to dim the light /screen on acer p221w monitor.It is very bright and i would like to know how to dim it
You should have some buttons on the front of the monitor, one of them is probrably a menue button which should allow you to adjust alot of the monitors settings from within there.
You can always download a manual by googling your monitors model number for exact instructions.
Nov 08, 2009 | Acer AL1916W 19" LCD Monitor
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
New fx 5500 installed, now viewing screen too big for monitor.
Hi there. You just need to adjust your resolution settings in the Nvidia Control Panel. Just right-click anywhere on the desktop and it should be in the list.
Hope that helps.
If you need anymore help, just reply to the post.
Tim
Apr 17, 2009 | XFX GeForce FX 5500 Graphic Card
The screen on my Audiovox FP1510 has gone dark
Yes, there are 4 backlight lamps but it seems you have a problem with the circuit, called inverter, that controls those lamps. m@nt
Mar 15, 2009 | Audiovox FP1520 15 in. LCD Television
Dark scree
I too have the same problem with the same monitor.. tv looks great OSD looks great.. pc is dim.. This has nothing to do with the inverter board or the backlight.. I believe that there is an issue with the components that render the Computer video.
Jan 17, 2008 | Samsung SyncMaster 17" TFT LCD Monitor
Screen goes dim under different user
could be an issue of his resolution and refresh rate settings are close to being out of range for the monitor. Try lowering these settings to get better performance.
Oct 25, 2007 | HP Vs17 17" LCD Flat Panel Monitor
Ejecting a dvd
It's a mechanical problem and the unit needs to be opened up and serviced by a repair shop.
Sep 22, 2007 | Audiovox VOD1023 Overhead LCD Monitor -...
Dim compaq s510 crt colored monitor
Hi, If you are comfortable working with tools, down to component level and know how to work around EHV areas, then it is possible to increase the brightness of any monitor including the Compaq S510. Make sure that the unit is unplug, Open the back cover and locate the FBT. You have to run/power on/attach a running PC to the unit with the cover off. Extreme care must be exercised. If you are not sure, you're better off asking a qualified service professional to do the adjustment. There two plastic slotted adjustables, focus & screen. Adjusting the screen changes the screen voltage going to the CRT. This will make the display go very dark or overly too bright. Adjust to your preference (not necessarily technically correct) The focus may also be adjusted this way. You have to run the unit with the back cover open for a couple of minutes to stabilize the voltages and the heater/CRT/ Adjust after a couple of minutes if necessary. In other monitors, there is a trimpot (small variable resistor) the adjusts the sub-bright. Further improvement maybe achieved by adding a 100uF/250V capacitor across the supply of the 70+VDC of the 3 gun transistors. If you are sure how to go about this, it is best to consult or seek the services of a qualified TV technician who can either show where and how or do the job himself. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Jul 31, 2007 | Compaq TFT5004 (Black) 15 in. Flat Panel...
Audiovox NPD5500 GPS Receiver Logo
118 people viewed this question
Top Audiovox GPS Experts
spyderdog8
Level 1 Expert
Are you an Audiovox GPS Expert? Answer questions, earn points and help others
