Question about Bosch KSU49630 Top Freezer Refrigerator
Have defrosted fridge and it tends to freeze up in tray in bottom of freezer which tends to make the fridge leak. Problem has been there from beginning, (after warranty ran out)
Check the hose or the drain hole in the back of the freezer make sure hose is connect and the drain hole is not plugged
Posted on Feb 07, 2009
May 13, 2013 | Bosch KSU49630 Top Freezer Refrigerator
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Mar 16, 2010 | Refrigerators
Oct 02, 2009 | Frigidaire FRS23H7C Side by Side...
Sep 29, 2009 | Audiovox Bosch 718 World Cellular Phone
Sep 13, 2009 | Refrigerators
Jul 02, 2009 | Refrigerators
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Feb 10, 2009 | Bosch KSU49630 Top Freezer Refrigerator
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
1,951 people viewed this question
Normal 0 false false false MicrosoftInternetExplorer4
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I have the same problem,warranty just ran out but its beenleaking on and off for ages,must be this model.This much Ive figured out,whathappens is the drain hole gets blocked from ice freezing over the hole at theback of freezer, the drain water has to go somewhere, since it cant leak out ofthe drain hole where it suppose to it ends up pooling under the vegecompartment before ending up on the kitchen floor.Now if this is your onlyproblem,someone suggested to me to run a piece of copper wire from thedefrost heater to the drain hole so no ice can build up there,so it willdefrost any ice that will build up over the drain hole,hence no more leakage.Todo this you'll have to take the back panel off and see for yourself,I did thisand Im a novice.Make sure you turn off and unplug the fridge first and wait forit to defrost.
Now I think I have other things wrong with mine,after leakage problem therefrigeration compartment wont cool anymore but the freezer part remainsworking as usual.Ive nailed this down to one of the following not working...Thermostat / timer / defrost heater.So one or more of these needs replacing.Imjust trying to look for a manual which shows the nuts and bolts or therefrigerator (not the "How to use" type manual which I have).
