Question about EliteGroup ECS A780GM-A Motherboard - AMD 780G, Socket AM2+, ATX, Audio, Video, HDMI, PCI Express 2.0, Gigabit
Monitor doesnt come on--just installed ecs a780GM mobo
Just build new comp. Installed everything but the monitor doesnt come on. Monitor does work--working on other comp.
  • 3 more comments
  • wannabecardg Feb 08, 2009
    The mobo didnt make any sound and i am using the onboard video, havent installed vid card yet. As far as i know the cpu is seated properly--it would only fit in one way to be able to close the lever. My system includes the mobo--AMD Athlon 64 5800--barracuda 500g hd--corsair memory(2x2048)--corsair 550w ps. The monitor is always on--I just disconnected it from other comp and ran cable over to new comp.
    I dont hear any beeps when I turn on the comp. All of the fans do start up-- cpu, case fans and ps fan. My dvd lights up and works. PS is connected as far is know have 24 cord connected to mobo.
    problem solved--12v power not properly connected.
    thanks for help
  • Art Ellison
    Art Ellison May 11, 2010
    Have you correctly connected the power supply? This can affect the video.
    Does the power supply fan start up?
    Does the CPU fan start up?
    If you hear beeps, how many are there? The beeps will tell you in a general way what is wrong.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Could be many things from memory or CPU not seated properly, if you have a pci or AGP video card installed that it may need to be reseated, Incompatible memory or CPU installed that the motherboard doesn't recognize or a bad motherboard. Besides the monitor not turned on, does the motherboard beep at all ?
  • 2,229 Answers
Glad you got the power reconnected and everything is working.
Posted on Feb 08, 2009
  • 58 Answers
Recheck all the hardware connections.
If it fine check the your CPU with another monitor. If it not works then fault with the CPU or software.
Hope this helps.
I installed a new intel mobo and now the monitor
that is not monitor problem .change the memory module
Mar 11, 2010 | LG L196WTQ Monitor
No monitor
Try this, reset the CMOS, but make sure that the power if fully turned off and the power cable connected to the power supply is disconnected. Change the jumper settings of the clr_cmos from 1-2 to 2-3 for approx. 10 secs. then return the jumper to 1-2. the locations is encircled on the image below.a55d1a2.jpg
Hope this helps.
Sep 26, 2009 | EliteGroup ECS A780GM-M3 AM2+ AMD 780G...
Video display problem, on MOBO A780GM-A
Well You Should Check Your Power Settings On The Computer Also I Had The Same Problem Last Year And What Happened Was That The Monitor Was Starting To Burn Out So I Got A New And Now It Works Great. I Also Checked The Monitor Setting Before Getting The New One
Jun 17, 2009 | Computers & Internet
Ecs motherboard audio problem
We do have the same motherboard and I am also running windows vista (64)
1) Try restoring your Operating System.
a) click START
b) go to PROGRAMS - ACCESSORIES - SYSTEM TOOLS - SYSTEM RESTORE
c) the choose to restore your system to an earlier time.
d) sellect the date where your system still on good condition.
2) Try uninstall the REALTECH on your Installed Programs then restart. After it detects "a new found hardware" , insert your CD and reinstall.
Hope this works for you.
regards,
-engrkoiled-
Mar 27, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Just put together A780GM-A MOBO With dual processor amd and used my harddrive from my old system. It comes up to cmos setup, but it won't boot to windows. It comes up with the screen that ask you if you...
That mean you if you put a hardisk into the mobo but you never format the disk along with the mobo you need to do so. you need to format/install win xp/vista on the hard drive so that it can work with the mobo.
So here is the point, if you have a new mobo, whenever you put hardisk on it, you must format the hardisk with win xp/vista.
Jan 29, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Updated bios problem on a780gm-a
I think you had a bad flash!
So re-download a new bios file from there web site and try again, with these instructions....
Updating the BIOS
You can download and install updated BIOS for this motherboard from the
manufacturer’s Web site. New BIOS provides support for new peripherals, improvements
in performance, or fixes for known bugs. Install new BIOS as follows:
1 If your motherboard has a BIOS protection jumper, change the setting to
allow BIOS flashing.
2 If your motherboard has an item called Firmware Write Protect in Advanced
BIOS features, disable it. (Firmware Write Protect prevents
BIOS from being overwritten.)
3 Create a bootable system disk. (Refer to Windows online help for
information on creating a bootable system disk.)
4 Download the Flash Utility and new BIOS file from the manufacturer’s
Web site. Copy these files to the system diskette you created in Step 3.
5 Turn off your computer and insert the system diskette in your computer’s
diskette drive. (You might need to run the Setup Utility and change the
boot priority items on the Advanced BIOS Features Setup page, to
force your computer to boot from the floppy diskette drive first.)
6 At the A:\ prompt, type the Flash Utility program name and the file name
of the new bios and then press <Enter>. Example: AMINF340.EXE
040706.ROM
7 When the installation is complete, remove the floppy diskette from the
diskette drive and restart your computer. If your motherboard has a
Flash BIOS jumper, reset the jumper to protect the newly installed BIOS
from being overwritten. The computer will restart automatically.
Hope This helps
Have a nice day!
Dec 27, 2008 | EliteGroup ECS A780GM-A Motherboard - AMD...
turn off the power and briefly press the power switch to discharge electricity. open up the case and locate the clear cmos jumper (check the manual for the exact location) move the jumper from pins 1 -2 to pins 2 - 3 for about 10mins. return the jumper to pins 1 - 2 and close up the case. and turn on the power supply and try to reboot again.
Dec 23, 2008 | EliteGroup ECS A780GM-A Motherboard - AMD...
Computer gets power, but doesn't display anything
remove your video card and plug it again.. if it doesnt work..
try plugging ur video card to *********** board built in video card and then ur on-board video card to you monitor..
this is what the nvidia guys mentioned on their video while announcing the release of the 9 series
May 07, 2008 | Toshiba Satellite P25-S607 Notebook
Dell computer windows xp pro. samsung syncmaster 731b cannot install right. says comp. cannot support default monitor installed ,
I need help monitor went blank and when I try to turn it back on it only blinks at the power button. took it apart and everything looks ok.
Mar 26, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Ge force 6200 video card installation
Hi dl1099, your motherboard L7VMM2 can only run a 4xAGP video card as noted in your manual pg. 2 Settings pg. 36
If your not getting video at boot up switch connectors on the video card.
http://www.amazon.com/XFX-PVT44AWANG-GeForce-256MB-S-Video/dp/B000CQ73PW
Mar 25, 2008 | EliteGroup L7VMM2 Motherboard
EliteGroup ECS A780GM-A Motherboard - AMD 780G, Socket AM2+, ATX, Audio, Video, HDMI, PCI Express 2.0, Gigabit Logo
140 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
