I did the easy thing and took out the filter. Still no water. Before I dig in to it, I wanted some advice on how to proceed.
thanks for your help in advance
SOURCE: Frigidaire - FSC23F7DS - water dispenser not working but ice maker is
take out the crisper drawers and see if the water tank is frozen is the light on the dispencer lighting up when you depress the paddle and look up in the dispencer to see if the acuating paddis broken we will go from there
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
My Frigidaire model FRS24ZGE leaks water from the bottom of the freezer door after using the water/ice dispenser. Any ideas on a fix?
I appreciate your inquiry, bela_desousa!
From the information you have provided the water dispenser on your Frigidaire refrigerator is not dispensing. Have you recently changed your water filter? If you water filter has not been changed and is dirty or clogged it could lead to potential failure of your water dispenser. If the filter has been changed it could be a faulty dispenser. I would suggest consulting with a professional technician for proper diagnosis and repair. Hopefully this is helpful. -Matt
