Question about Yamata FP202L Cordless Iron with Auto Shut-off
Yamata PSP990A Steam indicator light does not turn on.
No steam produced.
  • 4 more comments
  • berwickfamil Feb 07, 2009
    Will not produce steam.  The steam indicator light does not turn on.
  • berwickfamil Feb 08, 2009
    Where do I get another fuse to regulate the heating element?
    to confirm. i have the top apart. is the fuse white circular plastic secured by 2 screws with wires attached directly opposed from each other? i have sent Yamata email regarding replacement fuse.
    thank you
  • berwickfamil Feb 09, 2009
    I have been all over the web trying to find someone who has this part.  Yamata didn't even know the part number!  Can you please help.  Thank you.
    I will take a picture.  I sent you an exploded diagram.  Did that help?  Thank you.
  • berwickfamil Feb 23, 2009
    Yea!  Problem solved for $8!!!  Thank you!
  • 6,784 Answers
There may be a blockage inside one of the steam channels. they are very narrow and small so, any small object could produce this result of no steam.
Posted on Feb 07, 2009
  • Michael Masters
    Michael Masters Feb 07, 2009
    if its not a blockage, it a toltal system failure and will have to be repaired by the manufacture.
    Master:
  • 848 Answers
Hi
provide more information....
  • 3 more comments
  • gopinath pasupathy Feb 08, 2009
    fuse that regulates the heating element on has burned out.
    all you have to open the top, remove the heating plate. the fuse will be on the left, button shaped.replace the fuse and put everything back together and the unit should work.
    i cant find fuse for your model in website ....need to contact manufacturer to get the fuse.....provide your location to find local shops in your area......
    accept my solution by rating fixya if you find it helpful......
  • gopinath pasupathy Feb 09, 2009
    yes thats the fuse secured by two screws...
    can you just take snap of the fuse which you have in your model...so that i will find any compatible fuse for your iron ....since company people are not able to help you .......thats the only thing left out........i will try to find one and send you as soon as possible.......
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
Water bottle for pro steam iron PSS 2001
Here is the information of Yamata who do this product. If you contact them, they might be able to tell you where to get one, if not try ebay?
Add: 3450 NW 114 Avenue , Miami ,Fl 33178 , USA. Tel: (305)418-4421.
Toll Free: 1-888-2 YAMATA
(292-6282).
fax: (305)418-5036. E-mail: info@yamata.com
Jul 11, 2015 | Irons
My iron is getting hot but giving no steam can anyone advise
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
Iron producing lots of water
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 18, 2010 | Philips GC 8220 Iron
Yamata Steam iron 8800
Order Part Number 5 from Yamata at 305-418-4421
Yamata.com
Also see the parts diagram I just attached.
May 11, 2008 | Yamata Gravity Professional GSI-8800 Iron
Conair steam cleaner sc20 - plugged in, pushed button, no steam
If you need instructions go to www.HandBookLive.com. There are videos for GS4 and GS10 under Appliances category. It says that steam is produced in about 5-6 minutes after you turn power on. Also there is a low water indicator light on GS10 that kills power to teh unit if the water level is low. Maybe that's the problem... Not sure if sc20 is similar
Apr 15, 2008 | Conair Compact Garment Steamer Iron
Won't heat up
What sounds like is the fuse that governs the heating of the unit is either burned or not functioning. You can get a manual on how to fix that directly from feiyue yamata's site here. http://www.feiyueusa.com/Manual/FP202ELFuseChange.pdf
The problem is that if you have a psp990, it is not their item, it is a rebranded yamata so they dont have specific instructions for it. After you changed that fuse, i am almost positive you will be able to use your press again.
Jan 05, 2008 | Yamata PSP-990A Iron
Yamata FP202L Cordless Iron with Auto Shut-off Logo
Top Yamata Irons Experts
Are you a Yamata Iron Expert? Answer questions, earn points and help others
