Question about HP Pavilion a305w (DM181AR) PC Desktop
Monitor goes blank after seeing XP during boot up.
When I boot up, monitor shows the COMPAQ logo in red and the Windows XP logo. Desktop should appear next but the monitor goes blank instead. I replaced the video card and still have the same exact problem. Monitors work fine on other computers and they worked fine on this one until I unplugged it one day to rearrange the room. Tried SAFE MODE but nothing. Computer is a COMPAQ Presario 5000 from 2000.
Thanks, Dave
  • 2 more comments
  • damiley Feb 07, 2009
    Thanks JohnLeF,
    I just rebooted in Safe Mode and the screen is filled with these DOS messages:
    Windows\system32\Drivers\WMILB.Sys
    " " " \pci.sys
    " " '' \isapnp.sys etc...etc
    I will insert the monitor disc and see what happens
  • John LeFebvre May 11, 2010
    Is it a blue screen with lots of white writing on it? Does the first line say STOP or something similar?
    If so, it is the dreaded BSOD (Blue Screen of Death) - meaning something has happend that XP can't handle so it just stops.
    Copy down the first 2 lines of the screen and I'll see if I can diagnose any further...
    Do you remember changing any settings? Normally this sort of thing happens if the screen refresh rate is changed to a mode the monitor cannot support - it will switch itself off to prevent damage.
    I am surprised it does not work in safe mode however as this normally uses a ver low screen resolution and default refresh rate.
    On most monitors you can use the inbuilt menu system to display the screen rsolution and refresh details when the mode changes - try to turn this on (if available) to see what is happening.
  • Anonymous Mar 23, 2014
    Does the logo on the task bar mean it has downloaded if so what is the LABEL LABEL for What am i supposed to do?
    Sergeant:
    Champion:
  • 275 Answers
Did u replace the video card with the same kind of model ? i guess yes ... when system starts hit the f8 key and than go in to safe mode ... mouse wont work so use arrow on the keyboard .. and in the safe mode just log in to admin account if available or login to ur account and see if that still happens .. and if it doesnt ... remove the drivers for the graphic card from add and remove programs and restart the system and go in the normal mode and than install the drivers again ... and if the display disappears in the safe mode or u have install a different graphic card than ... reseat the memory cards and that should resolve the issue .... if that doesnt work out when the system starts hit f1 and stay on the BIOS screen for 30 mins if the system doesnt loose display than u need to reinstall OS ... that will surely work out ... the resolutions given above if u follow them correctly u will have a working system in no time
Posted on Feb 07, 2009
My GX520 pwr light is green, on the board is an amber Led, the somputer boots up, it goes the full process, until the arrow appears on the monitor. no Iconn are displayed on the desktop
If your computer gets to that stage, then I would guess you have an OS ( Operating System ) problem. Try booting from your XP installation CD. If that works then you may have to re-install Windows.
Jun 23, 2012 | Dell OptiPlex GX520 PC Desktop
My Dell Dimension 8400 desktop computer using Windows Xp operating system. The monitor shows the Xp Logo at first. Then the screen goes blank about 30 seconds into the boot process. What can I do to g
If you hit <F12> key upon boot-up and the monitor displays a boot menu, then you probably have an issue with your XP software. Meaning that you may have to re-install XP (by the way, XP is no longer supported).
Jan 28, 2012 | Dell Dimension 8400 PC Desktop
The monitor comes on then goes out.
Problem with appearing normal windows desktop... go to Safe Mode to remove any possible pop-ups or vga driver to see where the windows stands normally.
Oct 04, 2009 | HP Compaq FP5315 15" LCD Monitor
Monitor is not working
Try starting up in safe mode (press F8 just before the Windows logo pops up. If you can see your desktop this time, I would remove and reinstall your video driver.
Aug 02, 2009 | Compaq 7500 17" CRT Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Desktop doesnt boot.
If you have a windows XP recovery CD, try running that at boot.
also, try pressing the f8 key to boot windows in safe mode.
it sounds like a corrupted OS install: if you can't recover, you may have to reformat your hard drive and reinstall windows.
Mar 29, 2008 | Microsoft Windows XP Professional With...
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
MONITOR GOES BLANK
Did you recently change or install a program that would affect the resolution and card output? Try booting into safe mode by holding the "shift" key during boot. From there right-click on the desktop and hit 'properties'-> 'display properties' -> 'settings' , check your resolution and drop it to 800x600 and then reboot. If everything goes back in normally make sure you have the right windows drivers for your video card. You can also check the driver version and settings while you're in safe mode. Sometimes the windows update drivers can act screwy and I would recommend getting them directly from your card manufacturer.
Aug 19, 2007 | Dell Dimension 4600 PC Desktop
HP Pavilion a305w (DM181AR) PC Desktop Logo
668 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
