Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
Mini-sd is not being found
Both my sisters have the motorizr Z3 each with a 1 GB mini-sd card. They have usic on the cards but the phone will not show that the card it there. I put one of the cards in my nokia phone and the music will play find. Is there a setting or format I need to change for this phone to be able to see the SD card?
  • 3 Answers
Menu --> Fun & Apps --> Sounds --> Options --> View Storage Devices --> Make sure that you have "All" checked, not just Phone Memory or Memory Card. If you don't see both Phone Memory and Memory Card listed, than your phone is not recognizing the mini-sd card. Make sure you have it in the phone correctly, and if you do, then I suggest taking your phone to your carrier's local store and having them troubleshoot it for you. But this should fix it in just a few easy steps.
Posted on Feb 11, 2009
I can't delete the videos on my phone which are in video player... They dont show up in "my files" so im stuck :( somebody help please!
If you have a mini SD memory card in the phone, you can "MOVE" the videos to the SD card then using an adaptor, put the mini card in the adaptor, plug that into your computer or a friends computer that reads SD memory and delete them there. If you "MOVE" the videos to a mini card they will be gone from your phone.
Nov 12, 2010 | Samsung Jet S8000 Cell Phone
How do I download photos from LG VU (CU920) cell phone to my computer?
you can use the bluetooth feature if your computer also has bluetooth capability. if not, hopefully you're using a mini SD card. if your computer has a port for mini SD's, then just take the mini SD out of your phone and plug into your computer. if your computer has a regular SD port, then you need to get yourself a mini SD adapter. it looks just like an SD card, but it has a small opening to slide your mini into. if there are no SD ports on your computer, simply buy yourself a Flashdrive (thumbdrive) that has a port on it for mini SD cards. then, just plug that into your USB port.
if you're not using a mini SD card in your phone, then you need a data transfer cable, which you probably have to get from AT&T. i tried radio shack, but they didn't have them. In my experience, using a mini SD card provides the most compatibility. hope this helps.
Feb 06, 2010 | LG Vu CU920 Cellular Phone
How do i insert my mini SD card into the phone
Since you did not specify what is your phone model I reccomend the following:
1. Try looking on the sides of the phone for an empty space or some random lid.if there is such a thing then you've found the mini sd card.
2. Try removing the back lid of your phone and look for a special socket that matches the size of the mini SD card\
3. Try to remove the battery and see if there is any miniSD card space.
4. If it is a Nokia Symbyan phone then,this specific size of memory cards usualy have their slot near the headphones jack and they are covered with a thin lid.
Dec 18, 2009 | BenQ-Siemens E61 Cellular Phone
SD card issues
ur mobile does not support the 4 gb card its capable of supporting only til 2 gb so try a 2 gb card it wil be fast as old times
Mar 18, 2009 | Motorola Mobility KRZR K1m Cellular Phone
Mini-SD card is not found.
format ur card and ur phone also to format phone dial*#7370#
and try again
Best of luck
Feb 07, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Putting music on cell phone
MUSIC
This menu needs to be supported by mini SD Card.
It plays the music stored in the mini SD Card.
Copy the downloaded music from PC to mini SD Card,
and play the music stored in the mini SD Card through
your mobile phone.
Store music in the mp3 folder on the SD card.
1. Press [MENU] .
2. Scroll through the downloaded music to display the
music you want.
3. Select the music you want to play then press
[PLAY] or press [MENU]. Then select “Setting”,
press [OK], then 1.All Repeat, 2.Repeat,
3.Random.
Press [OK].
  • “mini SD Card” is connected to your phone, press
[MENU] to select 1. Setting, 2. Erase (Erase This/
Erase All), 3. Information.
Mar 30, 2008 | Audiovox CDM-8940 Cellular Phone
SD SLOT WONT READ 4GB MINI SD REG SPEED
try the 4gb card in a camera or phone. If the card is formatted in fat, it wont be recognized as the fat has a gb limit under 4 I believe. May want to reformat it in a camera or phone with fat32
Jan 24, 2008 | Compaq Presario X1000 Notebook
My new mini sd card wont work.
a virus maybe present in your card, try to format the card IN your camera not in your pc. [:0)
Jan 04, 2008 | Electronics - Others
Can't make a playlist
all you need to do is to format the mini sd card, and use USB cable to drag or copy and past mp3 audio files into your mini sd card. automatically it will allow you to make play list
Oct 18, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
