Question about Back to Basics 700 Smoothie Pro Work Top Blender
PLASTIC WHERE BADE IS ATTACHED HAS CRACK DOWN SIDE LEAKS
WHERE CAN I GET REPLACEMENT
  • Anonymous Feb 11, 2009
    I have the same problem. Anyone know where I can get this part?
I have the same problem with my blender
Posted on Feb 10, 2009
Tip
Failure of grinding, blending, or mixing kitchen appliances
Generally, a blade or grinding or blending/mixing part that is permanently attached to a metal shaft from the appliance motor is held on that shaft by a 'shear pin'. This pin breaks when something is put in the appliance that the grinder, mixer, blender can't gring, mix, or blend. This is to protect the motor from overload. Afterwards, The motor will continue to turn, but the blade or paddle, or whatever will not turn.
The shear pin needs to be replaced.
The shear pin passes through one side of the base of the bade/grinder/paddle assembly, through the motor shaft, and out the other side of the blade/grinder/paddle.
The piece of the pin must be removed from the shaft, and from the two sides of the blending/grinding part. This is generally a press-fit, and some effort may be required to accomplish this.
When the pieces have been removed, a common 'roll pin' of the appropriate diameter should be inserted to hol the turning part on the shaft. It must fit tightly, and some effort should be required to insert the new pin.
on Feb 07, 2010 | Blenders
I need a replacement blade,this one has a crack in it I've tried gluing it nothing works. Also these other parts need to be replaced also. Is it possible to get these parts new?
plastic can be heat welded using a soldering iron
there are youtube movies on how to do it
if you go google and type in --welding plastic --there will be pages on how to--
Oct 14, 2015 | Blenders
Blender leaks from bottom.
mcdevito75 here, Best Bet, contact Black & Decker online or by phone for info, also see any appliance repair shop in your area.
Jul 09, 2010 | Black & Decker BL600 ProBlend Work Top...
Need a new plastic pitcher for our villaware 5787 Smoothee
Got the number from your website and called direct to VillaWare...waiting to see if it arrives safe and sound, thanks so much!
PS...There are only a few left of this now discontinued model, so I'm glad I called (and I ordered 2 more instead)
Jun 01, 2009 | VillaWare 5787 Double Smoothee Work Top...
Leaking blender
It could be the gasket, could definitely be that crack in the collar, and even possibly the blade assembly - here is the official website to get all of those parts:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=4154&linkon=subsection&linkid=112&secid=53
-Tha Mp3 Doctor
Mar 31, 2009 | Back to Basics 600 Smoothie Elite Work Top...
Back to Basics 700 Smoothie Pro Work Top Blender Logo
171 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
