Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100 LE4000 Turns Off Randomly
My Toshiba Satellite A100 LE4000 turns itself off at random. I at first thought it was a cooling issue because the thing becomes hot as heck, but it now does it even if it has been off for hours.
It is plugged 95% of the time and the shut down issue has only happened when it is on AC power.
When it shuts down, no lights are on in the front, including the AC power light. When the lights are all off, it will not turn on for several minutes until the lights activate.
I have a brand new Toshiba power adapter that shows no signs of damage or wear.
I am thinking I may have to replace the battery but before I do that, I am hoping to get some advice first.
Any ideas?
Thanks!!!
  • akaattari Feb 07, 2009
    I updated the BIOS and now my laptop won't start
    It powers up for two seconds and just before the BIOS would load, it turns off
  • 64 Answers
There must be still a problem with your current cooling system. try cleaning up your laptops fan. cpu gets heated up very easily even if you turned it off for a while. you can do this by unscrewing the parts, the inside must be pretty dusty or something. this also happened to me but from a different unit.
also, try checking for the latest bios driver for your laptop and to be sure, download it on toshiba site itself. because latest drivers for your bios also manages the control of your cpu fans.
if you could also get access to your systems cooling options in bios, try checking if your cpu's temperature are doing fine.
but i prefer you cleaning up the inside fans as well. hope this helps.
Posted on Feb 07, 2009
  • 1 more comment
  • Sacraty
    Sacraty Feb 07, 2009
    what do u mean it wont start? can you be more specific please? thanks.
  • Sacraty
    Sacraty Feb 08, 2009
    ok heres what you gotta do. il be clear as possible as i can. have you updated the bios from the website? like from your manufacturers website?. i hope you did updated it only using the one that is specifically for your laptop.
    what you got is power issues, you could just remove the battery and plugged it in to work when your bios was still all good.
    the issue you are having now is mobo problem means motherboard because your cmos got messed up, you can fix this by going to the manufacturer itself and have em update it themselves.
    this is a common problem of Toshiba Satellite A100 LE4000.
    sorry if its my bad to not inform you to update bios specificaly desiged for the laptop. but the otherway around, you do realy have no chocie but to have it sent to the manufacturer for repairs.
  • Sacraty
    if your lucky enough, you could also try this.
    open your laptop
    remove battery of your motherboard (your laptop might go back to its original default bios) it looks like a watch battery.
    run your computer. if it works then
    put back bios battery and you can use your laptop. but i dont think you can use your laptop battery, remove it and just plug the laptop.
    your original problem is if you use the battery, your laptop shuts down, the issue is coming from the computers power itself not really battery problems. so whatever happens, you really have to send it to the manufacturer. you cant use the laptop with the battery on and unplugged though.. you can oly use it without the battery and plugged.
Toshiba Satelite shuts down randomly
Try reinstalling your windows, or the program you use.
Or, look if its overheating, buy a cooling pad, it's not really expensive and it helps alot.
Dec 28, 2012 | ASUS Computers & Internet
My Toshiba Satellite randomly turns itself off
please check your CPU temperature while it turning off
Jul 10, 2012 | Toshiba Satellite Computers & Internet
57" Toshiba projection TV randomly turns itself off and on
Look for loose connections in the power supply (plug, socket).
Feb 25, 2010 | Toshiba 57H82 57" Rear Projection...
What ram does SATELLITE 100 has ? Is it A100 DDR 1 or DDR2 ram ?
This is the Off the shelves specification
http://www3.dealtime.com/xPF-Toshiba-Toshiba-Satellite-A100-S211TD-Laptop
It varies depending if the owner or previous owner or the store upgraded or downgraded it.
Apr 03, 2009 | Toshiba Satellite A100-S211TD Notebook
Toshiba A205-S4607 Laptop
This may be a problem if your laptop has problems with heat. Being in a cool room with a lot of air-flow should solve this.
Although your laptop may have 'brain-damage' as such. In the respect that if you've dropped the laptop before or it has taken hits etc it may randomly turn it self on, or refuse to boot. If this is the case, there's no real way to deal with it.
Feb 20, 2009 | Toshiba Satellite A215-S4747 Notebook
My toshiba satellite p200 keeps turning off randomly.
Often this indicates that the battery is nearing its end of life. Even when plug and using the AC adapter/charger, this would occur if the electrical consumption is always at its peak. Noticeable is especially when the built-in WiFi card is in use.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 22, 2008 | Toshiba Computers & Internet
Powers on and off randomly
one of your tubes are bad...call tech
Nov 26, 2007 | Toshiba TP55H60 55" Rear Projection...
Overheating? Satellite A105-S2021
Hi, We see alot of overheating problems on Toshiba laptops. The problem is there is a build up of dust and hair inside the laptop over the cooling vents. What you can do is buy a can of compressed air and squirt it in bursts thru the vents and hoefully clear the dust. If you are confident enough with a screwdriver, you can do a better job if you take off the bottom panel and clean the dust off yourself. This picture illustrates what Im talking about:
Aug 21, 2007 | Toshiba Satellite A105 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
388 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
