Back to:
Tags:
Hawking HPS12U Print Server
ERROR Can't create file: pslog
By M0nica L - usenet poster
Do you also have Linux installed?
Pslog is a process logger for A Linux system. If this is not the case, this
is often related to DEBUG.TXT/W32/Rbot-T variants or @pslog.co.nz
All the Best,
Kelly
Microsoft-MVP Windows?? XP
2004 Windows MVP "Winny" Award
Troubleshooting Windows XP
Taskbar Repair Tool Plus!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 07, 2008
Not Rated (0)
iernst
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
i believe this has to do with the antivirus not accepting the "printserver utilities". namely, some antiviruses in my case McAffee confuse the pslog file created by the "printserver utilities " (in my case the ones for a Canyon router) with some virus with the same name. updating the utilities (mentioned by someone else with the sameproblem) did replaced the "bad name" as the software producers changed the name of the file in the new version. but not in my case. so i still don't know what to do. maybe installing the utilities in a different drive than the system drive would fix the problem, maybe the antivirus allows me eventually to use the filename. i'll try later, now i can live with clicking 7 times ok.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on ERROR Can't create file: pslog:
I don't want to Accept this solution
Solution #2
posted on Aug 01, 2007
Not Rated (0)
Lizzy
Rating: 0%, 0 votes
I experienced the same problem after I had installed the supporting
software
for the Hawking HPS12U print server. I uninstalled that software;
then
downloaded and installed the updated version. That eliminated the
problem.
aliasinkc
aliasinkc's Profile: #
View this thread: #
Thank You!
Solution #3
Not Rated (0)
Rachel007
Rating: 0%, 0 votes
Go to Start with PS. If there Uncheck and Apply
OK. Restart and see if you get the message.
do you fix this?
Thank You!
Can you Help with these Print Servers problems?
Print Servers
examples of graphs of the fundamental functions and...
Print Servers
I've changed the cartrige and I did remove the tape before...
Print Servers
code sc990
I can not make the PS detect an HP printer. What can be...
Print Servers
We have the card. What else do we need
Loading problems.
Repair Service
Find Print Server Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
