Question about Maytag Neptune MAH5500B Front Load Washer
Washer over fills I think its the presher switch but I dont now where it is on m washer it is a mah5500bww
    Scholar:
  • 99 Answers
This is joyce;
go to maytag .com and download your document put in your model and ser# if it ask for it and you will be able to dowload your info so you will be able to find what you are looking for.
thanks
joyce
Posted on Feb 07, 2009
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
1991 corolla oil light is flashing
dont run your engine till you have the oil presher checked out,,,if it is low on presher you will burn out your motor,,,change the oil presher switch it could have gone faulty
Nov 28, 2010 | 1991 Toyota Corolla
2006 chevy trailblazer
have the presher switch checked out it could be faulty,,dont drive the car or run the engine till you know you have oil presher,,,your engine wont live very long without oil presher,,,only minuets at best!!!
Jul 13, 2010 | 2006 Chevrolet Trailblazer
The wash cycle puts in too little water and ends up with an oL signal
there is an over fill switch in the washer,,there is a pipe leading up to it when water go.s into the tub the water presher fills the tube up and when the presher is right it turns off the flow,,, if it "times out" becouse it took to long to fill up it shuts off the water flow if this tube is blocked up with gunk??? it wont work very well,,,if its gone fulty it also stops the flow of water ,,,hope this help you out?
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing maching overflows
inside the washer is a fill valve it has a tube from the bottom of the tub leading to this valve if the tube is blocked with sope the washer over fills clear this tube first also if there are any holes in it it still over fills the washer, the valve works on air presher,,as the washer fills the air presher builds up in the tube and shuts this valve off stoping the flow of water into the washer,,,ok? sorry but me spelling is roten?
May 05, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
The light and buzzer comes on for oil pressure but oil is fine and pressure is good how do i turn it off
you dont,,,,first replace the oil presher sender switch if the oil light and buzzer are still on then use an oil presher gauge to check that there realy is oil presher in the engine if there is presher look for a fult in the wireing
Feb 23, 2010 | 1988 Volkswagen Cabriolet
Have a maytag mah5500bww replaced door lock still do and fl code
fl is usally a water not detected problem,, check ur fill hoses for kinks make sure ur water is on,, possibly have a bad fill valve..
Feb 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG MAH5500BWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Will fill with water but not continue with rest of cycles
hey i like that washer i have one too.so no tumble after fill? just dead! that may be boards because door latch would come into play a minute later.your wiring diagram in the consoel will give you some clues.you would have to call maytag on any board warrenty.but i dont think its that long.God bless ,tom
Jan 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
