Question about Datel Action Replay Max for PlayStation 2, Game Boy Advance, Nintendo DS
PS2 controller problem
My Intec PS2 wireless controller (Model PS2-7089-A) right analog stick doesn't work when it is pushed down or to the right.
Hi! Suddenly, the left analog stick of my controller stopped working when i push it down or to the right. Do you think that it's a simple problem that i can solve it alone, by opening the controll
Depending on how old the controller is you may have simply overused it to the point that the connections are worn out. You would need to have some idea of what the soldered connections were supposed to look like inside after you opened it up. But be warned some of these controllers can be quite difficult to put back together. When you open it up make sure its face down (Buttons down) and keep it that way or all the buttons will fall out and it can be a pain to get them all back in where they need to be.
Mar 25, 2013 | Intec PlayStation 3 Turbo Shock III...
How do i connect my intec ps2-7085-c
you should have 2 AA batteries but please note that the analog feature...(the center button between the sticks) will not work on these controllers. remember these are aftermarket controllers. their cheap.
Jul 23, 2012 | Audio Players & Recorders
The PS2 is not responding to the remote. "PS2" button light up, when pushed & flashed until another button is pushed. When this happens, the sensor light on the receiver lights up and flashes too. ...
Today I bought the Phillips SRU5107/27 Universal Remote Control and I was able to programmed my intec PS2 Remote Control. This control has the "learn" feature and you can program every single button and feature of your Intec.
Feb 21, 2010 | Intec G7322 Remote Control
Looking for a ubisoft game manual and not sure if this is a location that will help..not much of a gamer, but need manual for ps2 Heroes of the Pacific game. I looked on the "ubisoft" site but didn't see...
FLIGHT CONTROLS blacklinespacer.gif Steering or Roll: Left analog stick Left/Right Change Pitch of Plane: Left analog stick Up/Down Roll Left/Right/Move Vertical Rudder Left/Right: Right analog stick Left/Right Throttle: Right analog stick Up/Down Engage Warspeed: R3 (click right stick)
blacklinespacer.gif COMBAT CONTROLS blacklinespacer.gif Give Wingmen Order: Attack: Directional Up Give Wingmen Order: Defend: Directional Down Give Wingmen Order: Break: Directional Left Give Wingmen Order:Form Upk: Directional Right Next Target: x.gif Closest Air Target: Hold x.gif Rear View: triangle.gif Cycle Secondary Weapons: square_white.gif Next Objective: circle.gif Closest Objective: Hold circle.gif Target Camera: l2.gif Fire Secondary Weapon: l1.gif Zoom In Gunsights: r2.gif Pause Menu: Start Change View: Select
From http://www.gamesegment.com/PS2/instructions.cfm/id/6386730
Nov 17, 2009 | Video Game Consoles & Games
Right analog stick not working
Check the controls on the game's control section. If you play another game that uses the right analog control and it works on that game then it's the control set up for FIFA. Make sure that the analog control light is on when the game boots up. Sometimes if the analog control light is not on when you turn the game on and you turn it on afterwards, the analog stick controls don't work properly. That happened to me on NFS Pro Street. If this helped you leave feedback please. FIXYA!
Feb 19, 2009 | Sony PS2 Dual Shock 2 Controller...
My PS2 controller's L3 analog stick is broken.
I think I know exactly why. I bet you have a Pelican controller huh? Those analogs wear out after a while. You need to go buy another one, lol, sorry. They are only 10 bucks. Please rate!
Jan 01, 2009 | Sony PS2 Dual Shock 2 Controller...
Can't connect nerf ps2 controller to its receiver.
the L3 button is Left thumstick pressed inward
R3 is right thumstick pressed inward ;P
pls rate .
Dec 16, 2008 | Pelikan Performance Designed Products...
Controller Problem
most probably the controller's carbon button inside the controller is already worn out and is sticking on the controller's printed circuit board (PCB) there are some replacement carbon button that can be bought for a cheap price
or
if you are using an analog controller, check if the analog stick is loose in feeling, this might affect the controls as well because good working analog sticks are a little stiff when pushed
Jun 30, 2008 | Sony PlayStation 2 (PS2) Console
Intec Rechargeable Wireless Controller PS2
where is the b button at on a wireless controller for a ps2
Nov 22, 2007 | Intec XBOX CONTROLLER- CYBER PAD...
L3 and R3 problems
L3 and R3 r yr analog buttons just simply push down on them
Oct 01, 2007 | Sony PlayStation 2 (PS2) Console
Datel Action Replay Max for PlayStation 2, Game Boy Advance, Nintendo DS Logo
73 people viewed this question
Top Datel Video Game Consoles & Games Experts
Michael Galve
Michael Galve
Martin Murray
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
