Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
I have a Frigidaire, Electrolux washer dryer combo. The Model number is GLET1031CSO. Neither the washer nor the dryer will work unless the washer is set on spin cycle. There seems to be no power to the unit, but when the washer is turned on with the dial turned to spin and I start the dryer, they both start up and run until the washer cycle ends - then they both stop. I opened the unit up and can't find any wires out of place, but I'm pretty sure it is an electrical problem. Any ideas?
  • Anonymous Feb 25, 2009
    I have the same problem with my FEX831CSO model .
  • Jury Duty Sep 02, 2012
    Mine is also doing the exact same thing... if anyone has an idea of what I could check, I'll post back any solutions I may find. Oh, and after checking, yes it's hooked up to 30 amp breaker w/ 30 amp wire. Any other suggestions are greatly appreciated.
Are you connected to a 30 amp breaker w/ 30 amp wire?
Posted on Feb 23, 2009
Frigidaire Washer Dryer Combo (Stacked) We had to have the power shut off to our house. Now that it is turned back on, our washer dryer combo won't start.
Thank you for your inquiry, Caroline!
From the information you have provided your Frigidaire laundry center is no longer working. I understand that you had to shut off power to your house and now your laundry center is not coming on. It sounds like you could have a possible short within your timer. I would recommend performing a reset on your laundry center and you can do that by unplugging the power cord for roughly ten minutes. If you continue to have issues with your dishwasher can you provide me with your model number? In order to locate your model number you can find the serial tag and that should be located on the inside wall of your dishwasher. I look forward to assisting you further. -OOS
Mar 23, 2015 | Koolatron 1.7cuft Thermoelectric Fridge
Why would a frigidaire flse60rgs1 combo dryer runs but not heat and washer not start?
check out house breaker and could be heating element problem or thermostat issues ,not enough info for more respond .
May 18, 2014 | Washing Machines
My frigidaire glet1031cso will not spin
Hello Michael Fussner - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit
Apr 14, 2013 | Electrolux EW1209i Front Load Washer /...
Grease leaking out from under adgitator
Hi and welcome to FixYa, I am Kelly. After looking at your model number the only source for the grease that your noticing has to be coming from the upper transmission seal. Unfortunately the seal is not listed as a single item for purchase. The only listing is for the entire transmission assembly. Item 3 this link:
. http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-dryer-combo-Parts/Model-FLSE60RGS1/1428/0152000/P0307249/00006?blt=06&prst=&shdMod=
The transmission part number is: 131878411 that is now superceded by PN 134736400
We used several screws in the seal and then wrap the screws with 0.020 lock wire to pull them out.
What really stinks is... this transmission seal can be replaced and can be bought at an automotive parts supply IF you have the sample in hand. The other problem anyone would have in replacing the seal is that you have to make a new gasket for the tranmission and discard / replace the gear oil in the tranmission once you open it. It is not a repair for the novice mechanic.
The agitator can be removed by taking off items 54 - 57 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-dryer-combo-Parts/Model-FLSE60RGS1/1428/0152000/P0307249/00005?blt=06&prst=&shdMod=
Here is a pdf file with all part numbers on pages 4 - 7 for this repait EXCEPT the upper transmission seal.
ftp://ftp.electrolux-na.com/prodinfo_pdf/webster/95375481.pdf
( I know that this manual is not 100 % exactly like your unit but the parts are 100% the same. )
Any other parts can be found on line here:
We replace our own UPPER grease seals vs the whole transmission assembly. It is always a very time consuming / labor intensive repair.
Thanks for choosing FixYa,
Kelly
Feb 24, 2011 | Washing Machines
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
Clothes dryer squeaks when running
Fixing Frigidaire model # FER641FSO, not stacking, but had similar problem. turnsout one of the coils came off. might try that...
Mar 01, 2009 | Frigidaire GLER331A Electric Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
1,266 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
