Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
1.3HP CRAFTSMAN CHAMPION GARAGE DOOR OPENER-NEW IN 2004
My garage door is started giving me issues. When to open the garage door from the button on the wall, it started to open, then stopped. I would press the wall button again, then the door will go back down. I would then press the wall mount opener again, and nothing, the green light on the wall mount is not lit up anymore. I have to reset the main control box, then it will work once, then stop working again. I pulled the string to make sure the garage door is free and opening and closing manually, which it did. Hooked it back up, same issues.
  • Vince Heuser May 11, 2010
    Check the springs and cables on the door to make sure they are not broke
  • 30 Answers
Well sounds like its a pressure setting. you said you open the door by hand? Was it easy to do? Ask your self this can a 15 year old kid open it and close it? If so then it sounds like its a presure setting There should be two blue slots on your opener with numbers 1-9 says up and down force. Turn the up force towards the bigger number. Just a little bit. But before you do that as the other guy stated make sure that your cables and springs are working. Spring depending on your doors can be in three places but we going to assume you has the most common set up so look over the top of your door (with it closed) you should eb able to see a tube running across there. and somewhere in the in middle a set of spring look at the spring to make sure that you dont see any of the tube showing in the springs. Becare not to touch the spring as they are under a lot of stress.
Posted on Feb 10, 2009
Sears Craftsman 1/3HP garage door opener problem
If motor continues to run but no chain action check for missing chain tooth or cam gear worn.
Sep 22, 2017 | Sears Craftsman LiftMaster Chamberlain...
All my door openers r craftsmans with the orange smart buttons at the sears store they sold me one that on the package will work with green or gray does not say orange i wanted to find out before i open...
Compatible with Chamberlain LiftMaster Security+ 390MHz garage door openers with redish orange learn button manufactured from 1997-2005.
Temporary password option to let you give friends, relatives or maintenance people limited access. Program code directly from keypad.
Compatible with garage door opener operator model numbers 1240R, 1245R, 1246R, 1255R, 1256R, 1265, 1280R, 1000SDR, 2000SDR, 1245 GMR, 1255GMR
The 977LM is new version of 976LM.
Taken from Garage repair information
Jul 17, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Model 2000 Chamberlain 1/3HP garage door opener manufactured 02/91 with a round yellow "learn" button, lost remote. Bought a replacement chamberlain remote, Model 956 which is supposed...
If the learn button is 'amber' the model 956 remote should work with it. Try this method for programming just in case your aren't.
Hold the button down on the remote while your press and immediately release the learn button. Main light should flash.
There is always the possibility that the receiver has quit working.
Nov 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote code for a merlin power lift
I think you will have better luck checking around the Australian forums for help with this door opener.
Mar 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Programming remote, unit will not flash.
The easiest way to program is to hold the button on the remote while you press and immediately release the smart/learn button. If it worked before there is no reason for it not to work now unless it totally failed.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener (1/2 hp) - light flashing
most of the time when the lights start flashing on them and they won't work it's something in the way of the eyes that cross the garage at the bottom are something bummed them and there not lining up no more check that first.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
466 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
