Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Error message - "data base is empty"
When I switch on my Aquos the message "data base is empty" appears. I can view analogue channels but just get his message when I switch to digital. Any ideas?
  • Circuit World
    Circuit World May 11, 2010
    Sounds like a software problem.....how old is your tv???
Hi John
I have the same problem, although my set is a 32". See my posting on AVForums.com (UK)
http://www.avforums.com/forums/freeview/984253-sharp-aquos-lc32d44e-losing-memory.html
My email address is pastel10@btinternet.com in case you want to contact me
Paul
Posted on Apr 24, 2009
My grandma has recently been gifted a Polaroid TV as a Christmas gift. When the free view channels had the TV reset she lost the signal to an outdoor cctv camera for the building. We can't seem to get it...
probably the camera is either analogue or video . How was it connected to the TV via the Aerial Cable or via an AV input
If the camera is Analogue it may be on a ATV channel. So you would need to switch the input Source on the remote for the tv and check the ATV channels. If it was on a AV then try checking the AV input sources.
The free view channels is probably DTV source . .
Jan 23, 2015 | Televison & Video
Using Ex Pat Shield, BBC progs no longer start and a notice, 'Task failed at step 0: config was empty.' (Or 'Task queue failed ditto' Everything worked fine just days ago.
I have exactly the same problem, same error message. I first noticed the problem yesterday (September 11). Error message appears when trying to watch live TV through iPlayer. BBC News Channel works OK from BBC News website. Live sports broadcasts work OK through BBC Sport website. I uninstalled and reinstalled Flash Player but it made no difference.
Sep 12, 2011 | AnchorFree Expat Shield
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
Shoud this model be able to record digital channels, as I have only been able to record analogue channels to date - I am based in Western Australia - I can view all the digital channels on my TV but to...
Samsung DVD R150 recorder only picks up channels 2 7 9 10 &28, no digital channels, is this all it will record or am I doing something wrong with the installation?
Dec 02, 2010 | Samsung DVD-R130 DVD Recorder
Problem, unable to access any digital channels. TV displays error message Database Empty, any way of removing this message and accessing DTV again. Thanks
If the database is empty you need to re load the system.
With your remote controller, go to menu and from that you need to select install or setup.
This will scan for all available channels and store them for use.
Hope that helps.
Nov 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Cannot tune all digital cahnnels on Sharp aquos
Start by doing a factory settings/ defaults on the Sharp rather than a normal automatic retune.This should then be ok. You need to empty the existing presets first so it will find the new type of signal BBC is now using.
If still not working for BBC1 +2 then look at whether you have too much aerial signal strength. (ie a booster/splitter that you could bypass)
Nov 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have 3 digital tv's one in the lounge/bedroom and kitchen for some reason last night, the tv's in the bedroom and kitchen lost all digital channels and the analogue channels were very poor to view snowy...
Loosing digital channels is equivlent to a snowy analog channel, check you cable connections, and splitters to the tv, since you have two of them out, it does not make sense that it is your tv. It is a conneciton in your cable line somewhere.
Sep 02, 2009 | Televison & Video
Database empty?
Set top box VSTBAW09
Error code: data base empty??
Aug 31, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Freeview channels (DTV) on a Sharp Aquos TV
On my Aquos it's saying no carrier and database empty what do I do, I have trying to reset TV but free view isn't coming on and it's saying carrier 0.
can anyone help
Nov 22, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
446 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
