Question about Kenmore 22422 Top Load Washer
Kenmore Elite #20992 can't remove back housing
Top load washer will not spin.  Hear gears grinding [guess they're stripped]. Want to remove back to check gears.
  • DAWhidby Feb 10, 2009
    This was good advice. Now I need to find out how to get the pump off since it is rusted to the motor shaft!!!! Oh well.
  • 135 Answers
Comes apart from the front. 2 screws on front of control psnel; flip it up. 2 clips to pry out; also ulplug lid switch. Cabinet lifts up from back and comes right off. Hope this helps!
Posted on Feb 08, 2009
  • Jim Balcum
    Jim Balcum Feb 10, 2009
    I've had to break them off on occasion myself. If you end up needing a gearcase, ebay usually has a good deal or two.
Front load washer will not spin
Good Afternoon Kevin,
I see that you are having trouble with your Frigidaire washer not spinning and making a grinding sound as if something were stripped. I also see that changing out the door lock and switch assembly, did not help the issue.
I would suggest contacting either the manufacturer or your local authorized technician for further assistance. They will be able to diagnose what is causing the grinding sound and better assist in resolving the grinding sound. Hope this helps.
-Best Regards-
WP
Apr 21, 2014 | Frigidaire FRT18HS6JS Stainless Steel Top...
Machine will not spin. Grinding noise like chain or gears are stripped. Does rear panel come off easily?
See the link below:
http://www.apwagner.com/index.php?main_page=model_lookup&model_num=GSW9650LW0&model_id=147396&manufacturer=
Then click on diagram 01 and/or 04. You must remove the top control panel to get to the large retainer clips that secure thge front panel and housing. Remove the decorative plastic covers on each end of the control panel to see the screws. The most common failure to spin cause is a broken motor drive coupling, which is shown on diagram 04, part ID #13.
Mar 08, 2011 | Whirlpool Ultimate Care II GSW9650LW Top...
KENMORE MODEL 110.20842990 MAKES LOAD BANGING NOISE DURING SPIN CYCLE EVEN WHEN EMPTY. NOISE IS LOWER ON SOFT SPIN THAN ON FAST
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20842990&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
In order of difficulty, there are three possibilities.
1. It's possible that the Motor Coupler is worn / broken.
This is a three part plastic and rubber device that transmits power from the motor to the transmission. If it's worn and slipping you may hear the plastic pieces grinding against each other.
It's an easy repair.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=2e8e02b3755ab86d8e046bc88e9db27b
If the Coupler is worn, it's an easy and inexpensive fix.
Before going further, I'd check and verify that all the springs and vibration pads are in place.
See the following for where / how they attach.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
2. It may be the clutch bands have worn.
See the following for how to remove the pump, motor and transmission. The clutch is on top of the transmission. Sears has replacement clutch bands.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to remove the drive tube and brake to change clutch bands.
3. If it isn't the motor coupler or clutch, it could be the "agitate cams" in the transmission.
These are plastic pieces that move the agitator drive shaft up about 1/4" when the washer goes into the spin cycle. If they are worn, you may hear a grinding noise.
Also see the Whirlpool / Kenmore service manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
See also a more detailed description from Whirlpool of how their transmissions work.
Remove the cabinet, pump, motor and transmission. YOU DON'T HAVE TO REMOVE THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=1051095663c7f2d5997fa53b976529d6
I had the same problem with major gear grinding during the spin cycle and this solved it.
The agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight gear oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Be sure to align the holes on the Motor Coupler correctly or the motor and transmission won't fit together correctly.
Following is also the Whirlpool parts list for their commercial top load direct drive washers that has a better description of the cams and the Whirlpool part numbers.
It is a bit of a messy job but much ($10 vs $170 for a transmission) less than having a service person replace the transmission.
Be sure to study the Service manual so that you can see exactly how the cams work.Also see the Whirlpool / Kenmore service manual for top load direct drive washers.
Jun 11, 2010 | Kenmore 22422 Top Load Washer
Kenmore washer 110 makes grinding noice only at first of spin cycle. is it the clutch?
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
See the following:
Mar 12, 2010 | Kenmore 15864/15862 Top Load Washer
Kenmore commercial washer making grinding noise
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82403140
See the following for how to remove the cabinet, pump, motor and transmission. YOU DON'T HAVE TO REMOVE THE AGITATORS OR TUB.
Within the transmission are a set of plastic cams that raise the agitator gear when moving into the spin cycle. If the cams are worn, the gear won't lift high enough (about 1/18") and the gears will grind.
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Following is also the Whirlpool parts list for their commercial top load direct drive washers that has a better description of the cams.
While you've got the motor and transmission out, you should check the Motor couplers for wear.
Jan 23, 2010 | Kenmore Washing Machines
I have a Kenmore 80 series washing machine and the spin cylcle isn't working. There is a loud grinding noise during the spin cycle and the tub doesn't spin.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This also assumes that:
1. The machine will agitate and go through the rest of the cycles.
2. It will pump out the water.
3. Since it tries to spin, the Lid Switch is OK.
The problem points to the clutch and / or transmission
See the following for how to pull the clutch on Kenmore top load direct drive washers.
If the clutch springs and pads seem OK, the problem points to the main spin gear inside of the transmission. If the clutch springs and/or pads are damaged, there is a rebuild kit for them.
Following is the Whirlpool / Kenmore installation and maintenance PDF on how their top load, direct drive, neutral drain washers work.
Here is another PDF of the Whirlpool parts list for their commercial washers, consumer models are basically the same.
If you look at the operation PDF you'll see how the transmission works when going into the spin cycle. If the "Neutral Drain" cams are intact, they drive the main spin gear which drives the spin gear connected to the clutch.
If the main spin gear is broken (It's a metal plate surrounded by plastic gears) you would hear a major grinding noise and the washer wouldn't spin.
Opening the transmission is not difficult but is a messy job. It holds about 14Oz. of oil.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the main spin gear or neutral drain assembly cams are damaged, they aren't too difficult to replace.
The Whirlpool Parts PDF has part numbers for both.
The Neutral drain assembly costs about $15 which is a lot less than $170 for a new transmission.
The Main spin gear is quite a bit more but still less than a transmission.
Oct 12, 2009 | Kenmore 24032\24036 Top Load Washer
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from sears.com
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool LSC9355DQO won't spin and makes grinding noise
grinding noises are never a good sign. My best guess is that the motor coupling is shot. Very inexpensive repair if you're handy. unplug and tip the machine back. locate the motor and remove the clips holding the motor/pump assembly to the transmission. carefully remove the motor and if the coupling is shot, replace. put it back together and should be good to go.
Aug 22, 2007 | Whirlpool LSB6200KQ Top Load Washer
Kenmore 22422 Top Load Washer Logo
262 people viewed this question
Sal De
fordexpert
Robert Rankin
