Question about Philips PM4S Remote Control
Phillips remote does not work.
The remote for my DVD/Surround sound fell in between the sides of the couch. It was missing for months. When we finally found it, it doesn't work. We replaced the batteries, but it didn't help. The old batteries had not leaked or corroded. I suspect that the buttons had been held in the pushed-in position all that time. Is there any way to fix it? The product number is rc19245008/01. Thanks.
Replace bateries.
Posted on Feb 08, 2009
    Scholar:
  • 84 Answers
Greetings....Well the first thing I want you to do...since you said that the batteries had no corrosion or leakage is to check the battery contact terminals(where the batteries make contact) for the slightest sign of rust or oxidation..Sometimes moisture will form inside of the cover especially stuck between couch cushions with limited air circulation..if you have the slightest oxidation..clean them with a small piece of extra fine sandpaper..install a different set of batteries.If this doesn't work...the infared transmitter(eye) may have burned out during the time the buttons were pushed.Usually...some functions on a bad remote may work while others may not....Since the remote may be totally dead...you may want get a replacement.If you want to get an exact replacement...you can go to www.remotes.com .They can get a high percentage of original remotes for most devices....I hope this was helpful...PEACE...
Posted on Jan 04, 2012
Want to activate HDMI and surround speakers without remote?
You will need the original remote access these functions, try www.sony.com contact customer support and the technical department, also try www.ebay.com type make and model of player and scroll through the list.
Jun 15, 2012 | Sony BDP-S550 Blu-Ray Player
I cannot get sound from the tv through the surround sound, speakers all tested and work ok and dvd sound comes through ok when playing dvd, radio works fine also, worked fine 2 days ago with sharp tv, have...
Hi, You have to make sure you are using the "audio out" from the dvd/surround into the "audio in" on your TV also in some case TVs will need to change the "input" with your remote to see where you connected your dvd/sur also some TVs have a switch for "n" or "off" for internal speakers and also you could have that option in your audio menu on your TV, Hope it help, good luck. Mike
Oct 19, 2010 | JVC TH-G30 Theater System
I need help hooking up my tv and dvd player to my surround sound
for your dvd player you just go from audio out on the back of the dvd played to the audio in on the surround sound. and you would do the same for the tv if it has an audio out. your surround sound shoud have more than 1 audio in. and then when you swicht from tv to dvd you might have change the channle, setting, source, or what ever it might be called on the surround sound. and if your tv does not have a audio out contact me at swinginflames@gmail.com and i try to help you. hope that works :)
Feb 22, 2009 | Durabrand 5.1 Surround Sound Computer...
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
Lost sound for DVD player
PRESS THE SIGNAL SELECT BUTTON THAT WILL ACTIVATE THE 5.1 SURROUND. IT WILL CHANGE FROM ANALOG TO DIGITAL OR DVD/LD TO DVD 5.1.
Jan 05, 2009 | Pioneer VSX-D411 Receiver
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
Remote Code
THE SURROUND SOUND REMOTE THAT CAME WITH MINE IS AD-100MTRS . for the surround sound system for the ad-1100s dvd palyer.. my surround sound no longer works. i do havethis remote still.. where are you located.
e-mail me back at:
MONSTERMUSIC@AOL.COM
use suject-remote for surround sound system.
Feb 08, 2008 | Aspire Digital AD-1100S DVD Player
Philips PM4S Remote Control Logo
296 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
