Question about Proview PL916S2 Monitor
Pl916s proview 19 inch flat screen moniter
I was given this monitor because they said it didn't work. It has power but I cannot get a screen to come up on it. I need to know what I have to do to fix this problem. It is in great shape and the lady didn't want to pay to fix the problem. Let me know what I have to do and to try to fix this problem. thank you. I have the same Proview PL916s and i have the same problem. I replaced all 6 470 25v and it worked for a while. then I replaced the 220 25v and still doing the same thing. It comes on for about 3 seconds and it goes black. the power indicator stays green. Do i just need to replace the whole board? I cannot find any parts store online that sales the inverter board.
  • jdknsg Mar 10, 2009
    Screen lights for a second the dims with dark vertical lines each time you turn it off and then back on, however, after leaving it turned on and connected to running pc for 20 or so minutes then turn it off and back on the screen comes up perfectly and works right as long as it is not powered down. A warmup problem?
I managed to solve the same problem by replacing the six 470uf 25v capacitors. I have notice that the old ones has a bulging top.
Posted on Mar 23, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Proview Master
  • 848 Answers
Pl916s proview 19 inch flat screen moniter? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
AI 0088 Proview 860 ALZ M713W Power Supply for PL916S
Posted on Nov 30, 2014
Product NO. PL916s Model NO. 900P I have a Proview monitor, which has always worked wonderfully. Recently my computer broke down and I'm using another computer with a small screen. I have misplaced...
Product NO. PL916s Model NO? This trouble maybe power supply or inverter boards is defective. first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
Jul 21, 2011 | Proview PL916S2 Monitor
My Proview monitor PL916s model# 900P built in 2004 suddenly shut off and will not turn back on. There were no previous problems with it and this is the 2nd monitor (same brand and model) which has done...
My Proview monitor PL916s model? This trouble maybe power supply or inverter boards is defective.
Apr 12, 2011 | Proview PL916S2 Monitor
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
Where can you get a power supply for a proview pl916s monitor
Where can you get a power supply for a proview pl916s monitor? This trouble maybe power supply or inverter boards is defective.
Oct 04, 2009 | Computers & Internet
I have Monitor Proview PL916S 900P It turns on
spc12b, Have you tried the flashlight test yet? How old is this monitor? Your monitor has a 2 types of power supplys in it. A switch-mode-power-supply and an "INVERTER" supply. One or both of them could be having a problem. The inverter needs DC from the smps to change it into AC to light up the cold-cathode-fluorescent-tubes that are hung in back of the lcd panel. Let me know results of flashlight test. After screen goes black, hold light 1-2" from screen at different angles. Let me know if you still can see the win-desktop screen even though it is still dark.. Bye for now. louie12fix on fixya or lmistyrel @aol.com
Aug 12, 2009 | Proview PL916S2 Monitor
Moniter clicking
check capacitors inside for damage is found replace them
Feb 13, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
LCD Monitor goes off after 2 sec.
Check all cracked solder joints and resoldered and check two smd transistors near the inversors good luck
Aug 11, 2008 | Proview PL913B 19" Flat Panel LCD Monitor
Monitor dark PRoview PL916s
try to contact an expert technician of monitor maybe there is a part of your monitor that is already defective, the controller of brightness and contrast.
Jan 14, 2008 | Computers & Internet
Hi, I, too, was given one of these monitors. Using a flashlight shine it at an angle to the screen and see if you see a computer screen showing under the beam of the flashlight. If you see a picture then the backlight or its circuit is not working. Check to see that the 4 cables going to the LCD display are plugged in all of the way. There are plugs on each of the cables with 2 wires to each plug.
Aug 22, 2006 | Proview PL913S 19" Flat Panel LCD Monitor
Proview PL916S2 Monitor Logo
508 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
