Question about Image Line FL Studio 8 XXL Full Version for PC, Mac
STATIC FEEDBACK IN SYTRUS
WHEN I USE TWO OR MORE TRACKS FROM SYTRUS I OFTEN GET AN CLICKING KINDA STATIC ESPECIALLY WHEN I START TO ADD DRUMS OR OTHER INSRUMENTS FROM OTHER GENERATERS LIKE KICKS,BASS,ETC. when i use the sytrus i get a static like feedbac on certain sounds
  • 19 Answers
In the audio settings put your latency buffer up more, the more underuns means your pc is trying to run harder than u let it. ( the more technical the somg the mor ticking/feedback, if u have buffer all the way up u needa better pc www.reverbnation.com/timcpatc for some music made with fl9
Posted on Mar 03, 2010
I believe I understand what your problem is. Try opening FL Studio and clicking "Options" from the menu and select "Audio Settings". The settings window should have appeared with the Audio tab under selection. With this window, look for the options within the "DirectSound properties" frame that says "Use polling", "Use hardware buffer" and "Use 32Bit buffer". Uncheck all of these options and then exit the Settings window. Exit and the re-open FL Studio. Has this been a solution?
Posted on Feb 10, 2009
Hi, can you please how i can delete the contents of a minidisc? I have tried to use the edit/delete function on the player but it says TrPROTECT. I have checked the minidisc and its not on protect mode.
Page 121 of the Manual states that on the Net MD you cannot delete tracks, groups or the entire disc contents.
In other words you need to have it connected to your PC to Add & Remove tracks.
Please leave feedback
Cheers
Andy
Apr 26, 2011 | Sony Net MD Walkman MZ-N910 Portable...
I have recorded 4 tracks and a rytham arrangement but when i try to convert to MP3 i get no drums?? Any ideas
For the drums to take effect you have to master the track before converting. The manual explains how to do this. Push "exit" and "utility" at the same time twice, then "play" and "record" (to start the recording of course).
Dec 14, 2010 | Boss Micro BR Digital Recorder
Clicking/Static Noises
If you unplug the chat-controller cable from your headset and controller, does the click/static noise go away? If yes, then you need a new chat-controller cable. Email support@turtlebeach.com for that. ------- If the noise remains even after you've disconnected the chat cable, then the problem is likely due to the presence of too many other Radio Frequency wireless devices competing with the X31 transmit/receive, especially if you have an 802.11n ("N") router made before Oct 2009. If that's the case, you should definitely contact Turtle Beach at support@turtlebeach.com and ask them for help with this.
Feb 02, 2010 | Voyetra Turtle Beach Ear Force X3 Wireless...
When bounce tracks on my micro-br there seems static going on
First of all, it would be better for you to pan the tracks, and bounce into 2 tracks for stereo separation.
Your "static" may stem from three pausible causes.
One, four tracks into mono may make your output a little muddy.
Two, watch the reverb - if you keep applying reverb after each bounce, it starts to sound bad.
Three, if you have drums/rhythm, turn it off while bouncing. Only have drums on when mastering, because they will keep getting re-recorded during bouncing.
Go to bossbr.net - The best place to get answers!!!!
Sep 27, 2009 | Boss Micro BR Digital Recorder
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Logitech Notebook Quickcam (SOUND PROBLEM)
Normal 0 If you have your speakers turned up to high it will give you feedback causing distortion and static. Sometimes even awith the speakers turned down low, feedback is possible.
I recommend using a headset when videoing. Hope this is of some help. Bud
Apr 22, 2009 | Logitech QuickCam Webcam
Drum set
I USE THE INTERNAL DRUM MACHINE ALL THE TIME, BUT ONLY ONE TRACK AT A TIME PER SONG. I CAN CUSTOMIZE THE SONG BY CHANGING THE TEMPO, STYLE, AND LENGTH. EACH SONG SOUND GREAT. TRY IT. (DAYSHIFT).
Jan 31, 2009 | Tascam 2488 Portastudio Multitrack...
Drums on sx3
Hi!
You can put the drums manually with the drum editor. To do that, place the left and right selectors (the blue zone you can loop), I mean select an area first. Then, double-click in the area, on the track you want to make the drums. A midi segment will appear on the time-line. Double-click this segment, and it will take you in a drum editor. It's easy to edit, you will get to know it fast.
May 26, 2008 | Steinberg Cubase SX3
Static
If you have recently upgraded to Windows Media Player 11, either manually or via Windows Update, this could be the problem.
In this case, uninstall Windows Media Player 11 from Add or Remove Programs, in Control panel.
Also uninstall Windows Media 11 runtime.
This will roll back to Windows Media Player 10.
If you are already using Media Player 10, this problem could also be caused by corrupt firmware on the player.
make sure you have Philips Device Manager installed, from the product CD.
Run Philips Device Manager, and select the restore or repair option, then follow the on-screen prompts.
This will format the player and re-flash the corrupt firmware. All tracks on the player will be deleted.
Reload a few tracks to test.
Mar 06, 2008 | Philips GoGear HDD1830 MP3 Player
Cant transfer anything to my player (e250)
i'm having a similar problem. every time i sync new music my computer tells me its on, but the tracks aren't on the player. it also refreshes every time i turn it on, which takes forever amd is getting really annoying. could this have something to do with my new microSD card?
Mar 05, 2007 | SanDisk Sansa e250 MP3 Player
Image Line FL Studio 8 XXL Full Version  for PC, Mac Logo
527 people viewed this question
Top Image Line Computers & Internet Experts
David Payne
David Payne
Are you an Image Line Computer and Internet Expert? Answer questions, earn points and help others
