Question about Lexmark X6170 All-In-One InkJet Printer
Replacing encoder strip om Lexmark X6170
The encoder strip came out of it's slot on back of cartridge,not only do i not know where the slot on back of cartridge is,don't know how to re-attach the strip.Don't know how the strip even came off in 1st place.But without any room to manuver or light enough to see inside how is a person suppose to beable to fix this stuff,when can't afford to have someone fix it for you or totally relace it.Were recieving error code 0502 before strip came out completly.
Any and all help would be apprieciated and pictures would be great if at all possible.Maybe even instructions on how to take the whole thing apart and put it back together.
Thank-you
  • mom2brk Mar 24, 2009
    My encdoer strip came out as well. Have no idea how it happened but I contacted Lexmark and they said basically, sorry go buy a new one. I have a 2500 series.
First unplug your printer...
Lift your printer top, like you are going to change your ink cartridges.
Unplug your scanner & control panel by disconnecting the 3 ribbon cables
Then, you will need a screwdriver (philips head). remove the screws (about 4) from the inside housing cover.
After you have this cover off...
You should be able to see the sides of the cartridge. Take your encoder strip (gently) and thread it through the back of the cartriidges. Note: There are small slits on the side where you can thread.
If the encoder strip has come completely off (there should be tension if it is connected), you will have to located the right and left "pins" to attach it back to. I have a lexmark x-2500 so, mine are on the metal frame. The right end (arrow up) attaches to a metal strip which points straight towards you (a part of the metal frame) with a small notch at the right end and on the left end there's a type of "punchout" pin which is a part of the metal frame. I had to slightly bend the right end pin to the right, just enough to create some tension & keep the encoder strip from popping back off. The left end pin should already be bent out to the left.
Hopefully, this helps someone
Posted on Jun 05, 2009
  • sportygirl36 Oct 28, 2010
    I had the same problem with me encoder strip popping off. THANK YOU SOOOOO MUCH!!! I tried tech support from Lexmark and they just told me that it was a malfunction and fixing it would cost me more than a new printer. Then, they tried to get me to buy a new printer from them... UGG!!! U were SUCH a help!!! Again, THANK YOU SO MUCH!!
Error Code???
The 0502 error can be caused by four different issues:
    1. A contaminated encoder strip
    2. An unseated encoder strip
    3. A faulty black/photo cartridge
    4. A faulty color cartridge
Your best look see at the problem would be www.lexmark.com >technical support> Model name >FAQs
May 04, 2009 | Lexmark X6170 All-In-One InkJet Printer
Reattach encoder strip? Lexmark 6170
Hardware Error 502:
Cause: The All-in-One is stalled.
  1. Press Power to turn your All-in-One off.
  2. Unplug the All-in-One.
  3. Check for paper jams.
  4. Plug in the All-in-One.
  5. Press Power to turn the All-in-One back on.
Thank you for using Fix Ya!
Have a great one!
Dec 27, 2008 | Lexmark X6170 All-In-One InkJet Printer
Cannot find the way to put the encoder strip in the slots at the back of the cartridge carriers. model is lexmark X6170
like many others who have Lexmark X6170 I had a problem when the page was partially printed, and the LCD screen on the printer would give me the hardware error 502. as i learned from this forum, but as well from the lexmark site the problem was with the encoder strip which runs on the back of the cartridge carriers (it's a grayish transparent strip running from left to right, attached with the small hooks on eather side; there is a good picture of it on this site). The solution for it, as many had said, was to to pull down and forward the encoder strip so it could fit into the slot on the back of the cartridge carriers. The maddening part is that you don't know where the slot is, how it looks like, and after 1 hour of futile attempts and feeling VERY stupid, I remembered that i have a small dentist's mirror (you know the one he uses to see your tooth from the difficult angle, anyway don't ask), I alligned it and found that the slot is exactly in the middle of the cartidge carriers (remember there are 2 cartridges), just under blue and black thingiies which look like a small batteries and are placed almost on the top of the carrier. Now the interesting thing with the slot is that you could see that you are suposed to put the strip in it from bellow, but in my case, and I don't know if that's same elsewhere, there was a thin plastic part obstructing the acces from bellow. Now there were some interesting questions; first how to put it back; and secondly how the hell did it fal out of there. The only possilble solution, from my point of view was to de-attach the strip from its hooks (left one is easy and well visible, the right one is a bit tricky, it's kind of wire which you have to pull slightly towards you), and then pull it throught he slot. Now I have to tell to every one that was a bit of work, mainly because I don't have fingers of the five year old, but after some time i managed to do it (it's also important you have a good light, to see what you're doing). After acertaining it was through (that mirror again), i re-attached the strip first left than right. I dont know if cleaning the metal rod helps i did it anyway, the strip was clean anyway after being in my hands for so many hours. Put the printer on, no error 502 on the screen, performed the hardware test, and printed several pages afterwards. Knock on wood it works all right now.
Dec 26, 2008 | Lexmark X6170 All-In-One InkJet Printer
Hardware error 0502
The encoder strip may have gone out of range of the sensor, or it might be dirty.
  1. Switch off the printer using the power button.
  2. Disconnect the power cable from the back of the Lexmark X5100/X6100 Series.
  3. Leave the power cable disconnected for 30 seconds.
  4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
  5. Take out both cartridges.
  6. Place an index finger on the encoder strip on either side of the cartridge carrier.
  7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
  8. Lightly press the strip first to the rear and then forward, if necessary.
  9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
  10. Reconnect the power cable and switch the printer on again.
  11. Try to print....
Good luck...
Dec 15, 2008 | Lexmark X6170 All-In-One InkJet Printer
My lexmark x6150 says hardware error 0502
Hardware Error 0502 on LCD Display
Cause
Resolution
You need to check the encoder strip on the printer. This is a clear strip running the length of the printer, above or behind the cartridge carrier.
Check the encoder strip
    2. Disconnect the power cable from the back of the printer.
      Click here for an enlarged view. The contacts on the back of the cartridge carrier are the ones you need to clean. IMPORTANT: Use a dry tissue.
    11. Perform the hardware test, first without the cartridges and then with both cartridges. Click on the applicable article link below.
      How to Perform the Hardware Test on the Lexmark X5150
      How to Perform the Hardware Test on the Lexmark X6150/X6170
    12. Make a standalone copy.
    13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
Thank you
Nov 26, 2008 | Lexmark X6150 All-In-One InkJet Printer
Cant receive a fax
HI try this its from the lexmark web site
Hardware Error 0502 on LCD Display ID:ENUS16536
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
11. Perform the hardware test without cartridges first and then with both cartridges.*
Nov 21, 2008 | Lexmark X6170 All-In-One InkJet Printer
Hardware error message 0502 shows up on the display. What does this mean?
Cause
Resolution
    The red arrow points to the encoder strip. Click here
  7. for an enlarged view.
  8. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
  9. Lightly press the strip first to the rear and then forward, if necessary.
  10. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
    Click here for an enlarged view. The contacts on the back of the cartridge carrier are the ones to clean. Use a dry tissue.
  11. Reconnect the power cable and switch the printer on again.
  12. Perform the hardware test first without cartridges and then with both cartridges. Click on the applicable document below. How to Perform the Hardware Test on the Lexmark X5150
  13. Make a standalone copy.
  14. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
Sep 16, 2008 | Lexmark X5150 All-In-One InkJet Printer
LEXMARK X6170 HARDWARE ERROR 0502
The problem is you can't see the slot, as it's in back of the carrier. I took a dental mirror that has a built-in light on it and found the slot. Without that it's impossible to see, and you'll just have to follow the directions by feel.
Nov 09, 2007 | Lexmark X6170 All-In-One InkJet Printer
Lexmark 6170 encoder strip reattach help needed
There is a spot where the strip goes through and it MUST be in this slot. It might be just a slot or it could be a hole it goes through. On all inkjets the strip will ALWAYS be straight and not pushed either frontward or backward, if it is, its not where is should be.
Sep 14, 2007 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
2,373 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
