Question about Panasonic KX-TG5632 Phone
Blank Screen Have KX-TG5632 Panasonic Digital Cordless Phone. One of the phones work with no problem. The other phone stopped showing anything on the screen. I can still make calls, receive calls, etc. Everything is OK except the screen is blank. Doesn't show dialing number, incoming number, etc. Just blank. I have tried changing batteries and unplugging the phone to no avail. Does anyone have any suggestions.
  • 65 Answers
SOURCE: Panasonic cordless phone KX-TG6052
reset the dial mode if it is on tone and you have pulse it will not dial out.
Posted on Feb 09, 2008
  • 201 Answers
SOURCE: We have a panasonic cordless
Does the phone base receiver also have power? If so, then it sounds like a phone wire may have been cut. How extensive was this electrical work? If an electrician cut your phone wire by mistake they should take care of the problem at no charge.
To eliminate any problems with your cordless phone, try plugging in a standard phone where your cordless unit is to see if the line works.
Posted on Jun 11, 2008
SOURCE: No dispaly on screen.
I fixed mine by opening the handset case, and discovering that nothing was wrong or corroded, except that one of the charger contacts (the big and shiny long ones at the bottom of the handset) was a little loose. The two screws at the bottom of the circuit board also hold the contacts in place. Make sure they're tightened if they seem even a tiny bit loose.
The LCD was totally fine, and my contact ribbon for that was held in by tape and glue, so there was no way to check for internal corrosion KX-tga560m.
Posted on Jul 15, 2008
SOURCE: Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Posted on Sep 10, 2009
Testimonial: "This responder did nothing but repeat my initial post and yet gets credit for a solution?"
  • 3 Answers
SOURCE: Panasonic kx-TG2352 can not dial ,phone works for
Believe it or not, I accidentally discovered you have to really press hard on the numbers to dial !!! I guess this happened as one is used to a light touch working on a cell etc
Posted on Dec 01, 2009
Handset display lights up but is blank
If the batteries in handset are old then replace it. Follow battery change instructions in this manual.
http://service.us.panasonic.com/OPERMANPDF/KXTG5631S.pdf
Sep 12, 2014 | Panasonic Lands Phones
Led display does not work on my panasonic 5.8Ghz phone KX-TG5632
I just spoke to Panasonic Tech Support about the LED screen being blank. FYI its blank on both my handsets - one which I never even use. He made me do a few button presses, etc but nothing worked. So he tells me I have a "loose connection on the LED" so I must have dropped the phone or something. I said NO, I never dropped the phone, and one of the handsets I never even used - and its happening on that one too. So bottom line you have to take it to a Panasonic repair center at your own expense if its over the one year warranty - for what I personally think is a flaw on their phone design. I think after so much time the LED screen just goes away...since its happening on both handsets, and neither of them were dropped. Its a shame because the phone works fine, but I need the LED screen for the mute button, etc. So my solution for you is to stay away from Panasonic phones and the lame customer support, and go buy a different brand.
Apr 02, 2011 | Panasonic KX-TG5632 Phone
How to change answering message on my panasonic kx-tg1033 cordless phone
http://www.retrevo.com/support/Panasonic-KX-TG1033S-Telephones-manual/id/2878dj083/t/2/
If you got to the above this is your manual.
Go to page 26 and this will help in changing your answer phone message.
Hope it helps!
Dec 30, 2009 | Panasonic KX-TG5632 Phone
KX-TG6051B panasonic cordless phone - lcd screen doesn't work
I am just now having the same problem tried everything short of taking it apart. got six years out of it.
Nov 01, 2008 | Panasonic KX-TG5632 Phone
Panasonic cordless phone,
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
Oct 16, 2008 | Panasonic KX-TG5632 Phone
Kx-tg5634m
i cant get my phone to work. it says no link to base move closer to base,try again.
Sep 18, 2008 | Panasonic KX-TG5632 Phone
You can get yours repaired at www.cordlessrepair.com , and if you send the handsets they will reregister them to your fixed base at no extra charge.
Feb 03, 2008 | Panasonic KX-TG5632 Phone
Panasonic KX-TG5632 Phone Logo
94 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
