2wire 2700HG-B Router
Problem for 2wire 2700HG-B Router (2700HGB)
Home Network sharing issues using 2wire wireless modem
By kbn505 on Feb 07, 2009
Before installing the 2wire wireless modem, didn't have any problem sharing desktop network (drive & printer) throughout the network using a Siemens 4100 Speedstream modem and Linksys model BEFW11S4. I have tried several things (i.e., deleting all shared components and then re-sharing each device), and still I could not share the resourses on the network. I setup a Home Network on each computer where each computer is assigned same workgroup.
Would like to know what I'm doing wrong in configuring my home network using the 2wire wireless modem (model # 2701HG-B).
Comments:
Feb 08, 2009
- Tried pinging between both computers and I get a "Request timed out". When access shared files from the Home Network tab, I get the shared printer but can't access any of the shared resources. Crazy but something is stopping the next action or execution of the response.
XP firewall is turned off, but my Virus protection firewall is active and I don't want to turn it off. Before going with 2wire modem, I had XP firewall active and Virus firewall active and I could share resources within network without any problem. Why is 2wire so different?
Tried and these are my results....
Clarification Request
Posted by vedhick on Feb 08, 2009
ok....
so whats happening when you go to my network palaces and then under my work group computers...is it detecting any computers or is it blank..if u see the computers just click on it and see if it see the shared folders and files...
what you can do is go check if any firewall is blocing the new sharing setup,,,
do this in both the computers,
click on run,type in cmd hit enter and then in the black box type in ipconfig and hit enter make a note of the ip address from both the computers,now the ip address from the 1st computer needs to be pinged from the 2nd computer and the ip address from the from 2nd computer needs to be pinged from the 1st computer.
how to ping,click on start,run type in cmd and hit enternet and the black box type in ping and then give a space adn then type in the ip adress (eg shud b like this ping 192.168.1.101) and hit enter if u get request timed out then there is a firewall blocking,if the ping is successfull we need to check other settings...
do this and let me know...
vedhick
Solution #1
posted on Mar 18, 2009
Not Rated)
Techie007
Rank: Master
Rating: 92%, 20 votes
Did you manually assign the IP address to your shared devices? If so, the Linksys and the 2wire have different IP schemes.
2wire Gateway IP address:
192.168.1.254
255.255.255.0
Do an ipconfig /all on your computer and compare it to the ip scheme on your devices.
Was this helpful?
Yes
No
Popular Solutions for 2wire 2700HG-B Router
Questions and Unsolved Problems for 2wire 2700HG-B Router
Do you recommend 2wire 2700HG-B Router (2700HGB)?
Answer
Answer
how can you use huawei ec168 for xbox live how do you hook it up
Answer
Everytime i try to switch it back to normal i open up any window andf it goes back to multilingual... (More)
Answer
Using BT ADSL broadband 2- wire hub & having problems with failure to connect to internet.... (More)
Answer
the ethernet and wireless lights are off for the whole day, but the other lights... (More)
Answer
wireless light on 2700 hg-b router is off how do i turn it on wireless light on 2wire 2700hg-b is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For 2wire 2700HG-B Router:
Top Router Experts
Rank: Guru Guru
Solutions: 3587
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
