Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
All off sudden.drive chain continually coming off 10yr craftsman
Could this be wheel bearings...little movement in shaft..and chain does seem too loose.....is there adjustment nuts for chain, that i'm overlooking?
3 Suggested Answers
SOURCE: drive chain loose and poped offmy snowblower
Two things you can do. First if you look close you may see a spot where you can adjust the chain tension. Nest your chain should have what is called master link. Look close and you will see a clip that undoes the link. Pull the link out and the chain will come apart. If you are not mechanically inclined take it to any small engine shop and they will take a link out for you and then you will be home free.Hope this helps. donnyb60
Posted on Mar 23, 2009
pepsiman1967
  • 216 Answers
SOURCE: My Craftsman GT 6000 (20
The item you are referring to is called a snap ring. You can purchase a small collection of snap rings from you local hardware store or automotive dealer. These snap rings can be viewed at the bottom of this filehttp://www.rotorclip.com/cat_pdfs/de.pdf or ordered from http://www.rotorclip.com/.
These links should get you the information you need to go to the local hardware store and get your parts.
Posted on Aug 04, 2010
1997 Nissan 200sx. Wheel vibration
jack the car up and give the see if the wheel has any movement left to right or top to bottom. If there is no movememnt then your cv joint is ok and tie rod is good. is the a noise when you make a tight turn left or right , it maybe a wheel bearing. Also you have checked the nuts on the wheel itself are all tight?
Jul 19, 2017 | Nissan 200SX Cars & Trucks
Sounds like rubbing or grinding, a constant on/off as if the drum were warped
sound like something catching on the wheel or something in the tyre, if it was a bearing it would rubbing sound constant, could be the splash guard catching, any accident can cause movement and could catch, jack the wheel up and spin it look in the tread, test bearing hands 12 to 6 and 3 to 9 and wiggle the wheel any excessive movement it could be the bearing or the lower ball joint. you need a 10mm gap disc and splash guard, if the gap is too small bent it back. .
Jul 16, 2017 | 1992 Toyota Pickup
Roper snowblower drive chain keeps coming off
sounds like you have either stretched chains or worn sprockets. Also check the outer bearing that the shafts fit into for wear. If they wear then the chain can't retain it's tension properly, get sloppy and then derail itself. Most likely your bearings is the problem.
Dec 02, 2013 | Craftsman 16" High Garden Tractor Snow and...
Two piece drive shaft vibrating
just take the drive shaft out and replace all u-joints (3) and ur center support bearing (1) in all on my 2002 gmc sierra 2wd it was 50 dollars
Dec 07, 2012 | 2007 GMC Sierra Classic
Both wheels have a noticeable wobble. Can this be corrected?
Yes, the wobble can be fixed. First, remove both wheels and check the shaft bearings/bushings for wear. Make certain the grinder is unplugged and mounted securely. Try moving the shafts up, down side to side; there should be little or no noticeable movement. If there is movement it is a major(time and money) problem. I'm not familiar with what the shafts ride on. It could be, ball bearings(the best-long lasting, least friction, most accurate, but expensive), sealed bearings(almost as good as ball bearings, with many of the same attributes) and bushings(least expensive to produce and fit and cause the most friction. If excessive up,down side to side movement is present a decision must be made as to how much money/time you want to invest. If the shaft exhibit little movement; check if the shaft is running true/straight. Turn the grinder by hand while observing the shaft for bends. If none are seen by eye use a magnetic base micrometer to check run out(deviation from straight). If a micrometer isn't available; bend a short length of wire(coat hanger works nicely) with a small hook on one end and then put a pointer end on the other. Put a screw thought the end with the hook to mount it to the base of the grinder. Then bend the pointed end so it just touches the shaft. Rotate the shaft and notice if the distance changes between the point of the wire and the grinder shaft. Repeat for the other side. A couple of thousands won't hurt. However, any more and the cost effectiveness of tearing the grinder apart straightening the shaft must be considered. The most common cause of grinding wheel wobble is the wheels becoming out of true and/or unbalanced. This is easily cured with a wheel dressiing tool. The tool grinds the wheels in place. By gringing the wheels on the grinder they balance the wheel, true the wheel to the shaft and clean it of imbeded soft materials, aluminum, wood and so forth.
Feb 23, 2011 | Dewalt DW758 Heavy Duty 8" bench grinder
I have a Craftsman 1/2 hp, mod # 139.53603. When I press the remote or the panel button there is a humming sound from the motor. I opened the panel on the back and did not see anything out of line, etc. ...
Is the trolley jammed against the bolt just in front of the motor? If so, loosen the chain until the tension is off the trolley and then run the motor until the door is closed. Now locate the up limit on the side of the motor unit and turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Jan 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
It is 2 wheel drive and is the drive shaft it has wheel bearing support is 2 part drive shaft and the noise is after 55 like every second like scraping noise
It can be a u joint,or the drive shaft bearing,some call it drive shaft support bearing,or swing bearing.Moving the drive shaft up,and down should tell you if the swing bearing is bad,it should not have no movement up,or down,or side to side.It should stay centered in the housing,surrounded by rubber.
Nov 21, 2009 | 2002 Chevrolet S-10
A grinding noise in the front end of my 2002 f250 super duty and its not the brakes
If it is a 2 wheel drive, it is probably your wheel bearings. If it a four wheel drive, it could be the front differential, the joints on the axle shafts, the locking hubs, or the wheel bearings. On the four wheel drive, crawl under the vehicle and grab the axle shafts and see where the excess movement is. Also try grabbing the tires and see if there is any movement. There shouldn't be any movement while the wheels are on the ground.
Mar 20, 2009 | 2002 Ford F250 Super Duty SuperCab
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
