Question about Miller Welding Tools
Ground lead arcs when I connect, and auto idle kicks up
Whenever I connect the ground lead it arcs and the engine speeds up like I'm welding, but I can't weld. Its like both leads are hot.
  • kkbolejack Feb 07, 2009
    machine is mounted to a truck and welding is being done on the workbench on the back. ground lead is attached to the metal I'm welding. Problem just started after 600 hours of welding with this setup.
  • Anonymous Mar 21, 2014
    When you touch wire to metal it arcs everytime without pulling trigger, but no wire feeds
    Problem Solver:
  • 11 Answers
Hi
what are you connecting the ground lead to?
Is the welding machine phisicaly in contact to what you are welding ?
Can you electrically insulate the welding machine from everything, say stand it on a sheet of timber?
Regards
Rob
Posted on Feb 07, 2009
  • Robert Lee Feb 08, 2009
    Hi
    try welding off the truck, so run some welding cables so that everything is isolated from the truck.
    does the welder opperate normally now?
    if it does then someware there is a short between the "hot" terminal of your welder and the chassis of the truck,
    so when you connect the ground cable to the bench( which is the chassis of the truck) the welder "thinks" its welding.
    does the welder have an aux supply for power tools?
    if there is anything pluged into this is it faulty take it out
    do you have a test meter (Volts, Amps, Ohms)?
    this would help in tracing the fault.
    are the welding cables in good condition, no bare copper showing along their length?
    try al this then come back to me
    regards
    rob
Tip
How to set ark welders with more than fifty foot of welding cable
This tip is referring to welding machines using fifty foot add on sections of welding leads.
Number one: Set the machine with just the stinger whip(six to eight foot long) and a fifty foot ground lead.The ground lead can be shorter.
Number two: Get a piece of scrap plate the same thickness as you will be welding.
Number three: Set the plate in the position you will be welding in and clamp the on ground to to plate.
Number four: Turn on machine and set amperage dial to the size of rod.(if your using 1/8 rod set for 125 which is the decimal equivalent of 1/8) using decimal equivalents will get you in the ball park but depending on the coating , thick or thin you will have to adjust from there.
This will work for rods like stainless that have high resistance to current.
Number five: Once you have the setting that you like add five amps for every fifty foot of lead your using.This works for copper leads that are half inch thick and that all connections are tight. One more thing,if the rod is eating a crater ahead of the arc your running to hot.
on Jun 10, 2011 | Welding Tools
How to do conecct arc welding machine bx1-250
The black lead is connected to the metal you are attempting to weld, it has the silver ground clamp connected to it
The remaining red lead with the electrode holder connected to it holds the electrode
These welders are also capable of using 125 & 230 vac, 1-phase current from your mains there is usually a switchable indicator on the machine allowing you to select the input voltage
Nov 01, 2014 | Welding Tools
Kende weld no arc
make sure your work-piece has a proper ground. and maybe check your gas connection. no leaks. maybe turn gas down.
Mar 27, 2013 | Welding Tools
My Hobart 140 will not get hot enough to make a weld. It will feed out the wire, make a spark, and the flux core wire will melt on top of the thin rouaght iron square tube fence but it will not melt into...
Hi:
Sounds like you have the wrong polarity in your machine. If you are using flux core wire, make sure to connect your ground clamp to the positive side and your gun to the negative side. Dial the right voltage and wire speed according to wire size and metal thickness.Let me know if this help.
Regards,D.S.
Nov 18, 2011 | Hobart Handler 140 Mig Welder
The arc sputters when welding. Tried changing the electrode tip and checked the ground.
I've had slot of experience with these migs. Usually when the arc sputters, it could mean 2 things, either the roller feed tension is too light, or the liner in the pistol lead is worn. It's the flex tube the wire travels through. If it's worn the wire will hang up or snag, causing the arc to sputter. If you tighten the roller tension, and the wire back-lashes, that's a sign to change the lead. First try adjusting the speed of the wire accordingly to the heat.
Jul 30, 2011 | Miller MATIC 140 MIG WELDING PKG w/cart...
Weld arc not stable. Wire feeds, good ground,
Arc blow could be the cause! Put your ground on the work piece and weld away from it. If you weld toward a ground clamp the magnetic forces will blow your arc around sometime. When taking a cert this simple mistake can make or break ya on your cap or reinforcement beads.
May 09, 2010 | Hobart Handler 140 Mig Welder
I have a airco super hornet welding generator/power plantthat will not strike arc it is engine driven
Adequate ground?
Power output at receptacles?. Connections are yusually the problem Engine speed 1800 rpms (high idle) good luck
Jul 26, 2009 | Welding Tools
Speed will not kick up when arc is struck
There are CT;s (current transformers) that the transformer output runs through and the AC outlets which sense the current flow and throttle it up from the control board.
Also, Is the throttle linkage free , not jammed up??
Apr 07, 2009 | Welding Tools
The ground clamp has voltage
WARNING ! You have an earth leak on the unit, before you do any more work with this set, have it checked by a qualified electrician, it can be HIGHLY dangerous to continue. the leakage can be on the mains side and can cause you serious injuries. dont atempt to repair or examine yourself.
Dec 26, 2008 | Miller Welding Tools
Welding Tools Logo
576 people viewed this question
Top Miller Welding Tools Experts
John Trevino
wadingriver
wadingriver
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
