ASUS P4P800-VM Motherboard
Problem for ASUS P4P800-VM Motherboard
Serial port connector for Asus Motherboard
By Pasty - usenet poster
On an Asus motherboard I am considering, there is a 10 pin connector to which
you can attach a 9 pin RS-232 port that sits in one of the slots on the back of
the chassis.
The so called COM module is 'purchased separately to quote the manual.
Anyone know where I can actually get one from?
I have done a bit of googling but so far without success
Michael Chare
Same Problem
Dec 29, 2008
-   I have a foxconn motherboard and the COM1 header is at the far right front corner of the board and the slots are at the far left rear corner of the board and I cannot find a 9-pin Serial to IDC-10 Plate that is long enough to reach I have a 9'' but need a 12 " cable.
-   Guest
Best Solution
posted on Aug 01, 2007
Very Helpful)
jessie25
Rank: Apprentice
Rating: 0%, 0 votes
Rather hit-and-miss, I'm afraid, and carried out over several weeks.
It would all have been MUCH easier if Asus had thought to document the pinout
of the COM connector on the motherboard so that I could tell whether any of
the 3rd-party connectors available from various places would be compatible.
You've lost me ... what's a Q-connector? I thought that was something to do
with case-front connections (power switch, power LED, disk activity LED, and
various i/o thingies)? I see that some Asus boards do list "ASUS Q-Connector"
among their features ... but, no, neither of my boards have that -- the front
panel connection is just a block of 20 header pins (some unused) onto which
the various case connections from my cases fit easily. Nothing 9-pin about any
of it.
The serial port connection on both my boards is a 10-pin header connection
(with one pin missing) that the 10-pin plug (with one pin blanked off) on the
cable of the COM port backplate just pushes over.
The boards I have are P4P800-VM and M2NPV-VM (both uATX boards with onboard
video, the former is a S478 intel board and the latter an AM2 nForce
430/6150). I believe the serial port connection is pretty-much standard across
the whole Asus range, though.
Which board(s) are you considering?
That's simple then - don't use Vista! You won't be missing much.
In fact, I suspect that all serial/parallel port cards use hardware that is so
standard that Vista will recognize it out-of-the-box -- no driver necessary --
but don't blame me if it doesn't!
You might have a problem with the COM ports on the card trying to use the same
i/o addresses as the ones on the motherboard, but this should be resolvable in
the BIOS setup and/or by jumpers on the card.
Cheers,
Daniel.
Was this helpful?
Yes
No
Solution #2
Very Helpful)
pawa
Rank: Apprentice
Rating: 0%, 0 votes
Thanks, Your searches have been much better than mine.
I have sent Kustompcs an email asking when they will get some more.
Did you Asus motherboard come with a Q-connector on the 9 pin motherboard
socket?
At the moment my knowledge of Asus mobos is limited to reading the instruction
manual.
I want to have a parallel port and have found that I can buy a Sweex 2 serial +
1 parallel port adapter, but of course there is no Vista driver - same goes for
the Sweex card reader!
Michael Chare
Was this helpful?
Yes
No
Solution #3
Helpful)
man1
Rank: Apprentice
Rating: 0%, 0 votes
My thoughts exactly! Though as a flat cable is used I presume that there are
fewer practical options.
AIUI the Q-connector is a 2 part block to which the above wires attach. You can
attach the wires to 1 part, then plug it into the other part on the mobo.
Asus P5B-V The onboard graphics do not appear to add much to the price and may
well be good enough for what I need. If I don't get a picture I won't be left
wondering whether it is the mobo or a graphics adapter that has died.
So I gather!
I live in hope and have also emailed Sweex!
Michael Chare
Was this helpful?
Yes
No
Solution #4
Helpful)
M0nica L
Rank: Apprentice
Rating: 0%, 0 votes
I've been trying to get the same thing.
The supplier of my motherboard (scan.co.uk) say they won't order it as it's
difficult to obtain and they have to order in bulk and then have difficulty
selling the rest of the batch. I see their point ... but I'm disappointed that
Scan aren't more obliging -- they seem quite good in other respects.
I contacted Asus through their website and got a reply from Asus in Shanghai
saying "I will try to pass your case to our colleague in UK to help you ASAP.
They will contact you soon. Do not worry". Needless to say that's the last I
heard from them.
I do know that you *can* buy the connectors from the Asus online store in the
US/Canada ... but they won't ship worldwide.
I spend some time searching the web and found several UK-based retailers who
sell serial port brackets, but not the Asus part. However there seems to be
more than one way that these things can be wired up, and I don't know which is
compatible with Asus's motherboard connector.
However, to cut a long story slightly less long, I have recently found that
KustomPCs stock the Asus brackets -- and at a very modest ??2 each -- and bought
some from them.
They are now showing the part as "Out of stock", though.
Cheers,
Daniel.
Was this helpful?
Yes
No
Solution #5
posted on Sep 11, 2007
Helpful)
albuck
Rank: Apprentice
Rating: 83%, 25 votes
I found two solutions to this problem, once I stopped searching for "COM module" and went looking for "internal serial cable".
1. In the junk pile of my local computer parts store, I dug out an internal serial port cable with bracket. It was unlabeled. They charged me $1. It worked fine, and it is in service now. The cable to the bracket was too short, so I can't mount the rear bracket in my case.
2. http://frontx.com sells internal serial cables for Asus motherboards. In fact, they track two different types of serial cables for motherboards and have all sorts of pinout diagrams and photos. Asus internal serial cables are FRONTX V1, part number CPX102-2. I ordered one for $6.70, with free shipping. It has a long cable, but the mounting bracket is shaped for use in FRONTX's front panel connector system, sold separately. I plan to let the serial connector flop out the back of my case.
Best regards,
Lester
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #6
posted on Sep 16, 2008
Very Helpful)
BernardBrook
Rank: Apprentice
Rating: 100%, 1 votes
Try this site for information and sourcing info.
www.scantips.com/serial-db9.html
Good luck.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #7
posted on Nov 09, 2009
Not Rated)
gibbie99
Rank: Guide
Rating: 85%, 1 votes
I have the same issue; the solution I am going to go with is to buy a USB to serial converter. This is actually a serial port with the UART chip onboard, and with USB pin-out. Its a hack to be sure, but just as cheap as getting the silly serial cable from ASUS.
Was this helpful?
Yes
No
Solution #8
posted on Jul 18, 2009
Not Rated)
dakj
Rank: Apprentice
Rating: 90%, 1 votes
Was this helpful?
Yes
No
Solution #9
posted on May 22, 2009
Not Rated)
ZenMasta
Rank: Apprentice
Rating: 0%, 0 votes
http://www.cablestogo.com like many of you guys I searched high and low, even ebay. But finally found these guys that have the serial port connect AND lpt as well as a bunch of other stuff. They have 16inch too, I'm just about to place my order.
Was this helpful?
Yes
No
Solution #10
posted on Sep 15, 2008
Not Rated)
nicoglycerin
Rank: Apprentice
Rating: 0%, 0 votes
This is called a Serial Backplate. I found one in Canada for myself at www.compunation.com/
Type "Serial back plate" in search box.
Was this helpful?
Yes
No
Solution #11
Not Rated)
Putty
Rank: Apprentice
Rating: 0%, 0 votes
Thank you for your kind offer. I have sent an email. :-)
Michael Chare
Was this helpful?
Yes
No
Solution #12
Not Rated)
Beresford
Rank: Apprentice
Rating: 0%, 0 votes
That arrangement used to be standard for serial and parallel ports on
all motherboards before the advent of ATX.
Let me have your address and I can send you one of each.
Thoss
Was this helpful?
Yes
No
Popular Solutions for ASUS P4P800-VM Motherboard
Questions and Unsolved Problems for ASUS P4P800-VM Motherboard
Do you recommend ASUS P4P800-VM Motherboard?
Answer
Answer
where do i find a software to flash my motherboard so a memory can work?(SIS761GX/965L CHIPSET)
Answer
hello ! I have D945GCPE intel motherboard in my PC ,now i want to expand the graphic card memory of... (More)
Answer
Where can I download a Micro Star MS 7502 motherboard manual?
Answer
Poler Expree O gauge Train, working all morning..Train goes arou7nd but the throttle is not... (More)
Answer
no video driver present since a reformat and can't seem to download, motherboard is a k8m400 for an... (More)
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
in Newport, KY
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
